labels, formats etc. I want to move these properties to another instance
together with some customizations I have created but the extended properties
are not available in the solutions manager. How can I move these?
Â
The UD Tables are been called from an existing form i.e.
Project Management form
Â
Regards
9.05.701 but do not know if it has been fixed in current release.
Steve
Tony Karugu
Sent: Friday, July 05, 2013 5:51 AM
Subject: [Vantage] RE: Extended Properties
I have added extended properties to a ud tables i.e. column
Regards
Thanks for the heads up.
Am using 9.05.702, if this is the case then it wasn't fixed in the release.Â
The solution just thought of today was resulted to copying from the UD Table List then paste updated on the LIVE,PILOT instances. Lot of work as we have several Forms and UD tables that have extended properties.
Regards
Anthony
Sent: Friday, July 5, 2013 2:19 PM
Subject: RE: [Vantage] RE: Extended Properties
Â
Solution manager Extended properties are currently broken in version
Steve
Tony Karugu
Regards
Greg Payne
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Tony Karugu
Sent: Saturday, July 06, 2013 4:38 AM
Subject: Re: [Vantage] RE: Extended Properties
Hi Steve,
Regards
Anthony
From: Vantage <vantage@...<mailto:vantage%40rmgfelm.com>>
Steve
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Tony Karugu
Regards
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Sue
> Â
> Â
> Regards
<div id="ygrps-yiv-1324161299yiv7416842701ygrp-text">
<div>Using Embedded customization you can put a custom rule on the field and popup a more descriptive message. Also depending on when you want to check the field put a BPM on the method (typically update) and popup a descriptive message.</div><div><br clear="none"></div><div>Jim Kinneman</div><div>Encompass Solutions, Inc</div>
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-mkp #ygrps-yiv-1324161299yiv7416842701hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-mkp #ygrps-yiv-1324161299yiv7416842701ads {
margin-bottom:10px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-mkp .ygrps-yiv-1324161299yiv7416842701ad {
padding:0 0;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-mkp .ygrps-yiv-1324161299yiv7416842701ad p {
margin:0;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-mkp .ygrps-yiv-1324161299yiv7416842701ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-sponsor #ygrps-yiv-1324161299yiv7416842701ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-sponsor #ygrps-yiv-1324161299yiv7416842701ygrp-lc #ygrps-yiv-1324161299yiv7416842701hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-sponsor #ygrps-yiv-1324161299yiv7416842701ygrp-lc .ygrps-yiv-1324161299yiv7416842701ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701activity span {
font-weight:700;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701activity span span {
color:#ff7900;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701activity span .ygrps-yiv-1324161299yiv7416842701underline {
text-decoration:underline;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 .ygrps-yiv-1324161299yiv7416842701attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 .ygrps-yiv-1324161299yiv7416842701attach div a {
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 .ygrps-yiv-1324161299yiv7416842701attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 .ygrps-yiv-1324161299yiv7416842701attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 .ygrps-yiv-1324161299yiv7416842701attach label a {
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 .ygrps-yiv-1324161299yiv7416842701bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 .ygrps-yiv-1324161299yiv7416842701bold a {
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 dd.ygrps-yiv-1324161299yiv7416842701last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 dd.ygrps-yiv-1324161299yiv7416842701last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 dd.ygrps-yiv-1324161299yiv7416842701last p span.ygrps-yiv-1324161299yiv7416842701yshortcuts {
margin-right:0;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 div.ygrps-yiv-1324161299yiv7416842701attach-table div div a {
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 div.ygrps-yiv-1324161299yiv7416842701attach-table {
width:400px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 div.ygrps-yiv-1324161299yiv7416842701file-title a, #ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 div.ygrps-yiv-1324161299yiv7416842701file-title a:active, #ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 div.ygrps-yiv-1324161299yiv7416842701file-title a:hover, #ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 div.ygrps-yiv-1324161299yiv7416842701file-title a:visited {
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 div.ygrps-yiv-1324161299yiv7416842701photo-title a, #ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 div.ygrps-yiv-1324161299yiv7416842701photo-title a:active, #ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 div.ygrps-yiv-1324161299yiv7416842701photo-title a:hover, #ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 div.ygrps-yiv-1324161299yiv7416842701photo-title a:visited {
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 div#ygrps-yiv-1324161299yiv7416842701ygrp-mlmsg #ygrps-yiv-1324161299yiv7416842701ygrp-msg p a span.ygrps-yiv-1324161299yiv7416842701yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 .ygrps-yiv-1324161299yiv7416842701green {
color:#628c2a;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 .ygrps-yiv-1324161299yiv7416842701MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 o {
font-size:0;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701photos div {
float:left;width:72px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701reco-category {
font-size:77%;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701reco-desc {
font-size:77%;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 .ygrps-yiv-1324161299yiv7416842701replbq {
margin:4px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-mlmsg select, #ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 input, #ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-mlmsg pre, #ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 code {
font:115% monospace;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-mlmsg #ygrps-yiv-1324161299yiv7416842701logo {
padding-bottom:10px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-msg p#ygrps-yiv-1324161299yiv7416842701attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-reco #ygrps-yiv-1324161299yiv7416842701reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-sponsor #ygrps-yiv-1324161299yiv7416842701ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-sponsor #ygrps-yiv-1324161299yiv7416842701ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-sponsor #ygrps-yiv-1324161299yiv7416842701ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1324161299 #ygrps-yiv-1324161299yiv7416842701 #ygrps-yiv-1324161299yiv7416842701ygrp-vital ul li:last-child {
border-right:none !important;}
