I know I have seen somewhere a fix for the “Export to Excel” from Epicor ERP 10.1.400. I get the error below when trying to export to Excel. Has anyone seen this error and know how to make it work properly.
Thanks!
Thanks!
Hi Josh,
Lots of posts on this ~ either close your open excel OR hold the alt key right after you click to copy to Excel. This will ask if you want to open another instance.
Nancy
Thank you! I knew it was around but I was not searching the correct keywords or something cause I could find it. That works great!
And when you get to 10.1.600+, check out the Excel OData import and bypass this step altogether. See the REST Novel for more info.
This issue went away for us when we upgraded from 10.1.400.32 to 10.2.200.14
