Export utility - left outer join?
Try this :
Cut and paste this in the Export Query then select the fields you want.
for each Vendor Where Vendor.Company = cur-comp no-lock,
each VendGrup Where VendGrup.Company = Vendor.Company
and VendGrup.GroupCode = Vendor.GroupCode no-lock:
I am able to pull all fields in these tables
Don Kolllmann
Wisconsin EPS
Sent: Wednesday, September 13, 2000 4:45 PM
To: vantage@egroups.com
Subject: RE: [Vantage] Export utility - left outer join ???
At 04:43 PM 9/13/2000 , you wrote:
>I can't duplicate your problem ... my export query looks different
>from yours. Mine comes out as:
Yup, that looks like what the wizard thing generated. It produces the
inner-join effect, where the vendors with no code are excluded. When it
didn't work, I looked over the syntax description in the online help. I
left out the WHEREs and BYs; then tried omitting EACH, using the OF
VENDOR, and what not.
And Don asked:
>What information are you looking to pull
>Just vendors name and group description?
Vendor name, address, CSZ, and some other Vendor table fields, as well as
the group description, and possibly some other joined tables later.
-Thanks,
WC
Wayne,
I can't duplicate your problem (it looks like my purchasing group
has actually entered groups for everything... Usually when I go poking
through the data like this, it's like looking under a rock: I always find
something slimy). However, I did notice that my export query looks different
BY VendGrup.GroupCode:
Don't know if that makes a difference...
Sent: Wednesday, September 13, 2000 3:15 PM
I'm having decent luck making simple exports work. But doing joins is
giving me headaches. I want to dump all vendors, along with their
GroupCode and VendGrup.Description. Some Vendors don't have a group code
(that's where the trouble starts)
each vendgrup of vendor:
Subject: [Vantage] Export utility - left outer join ???
Hi Wayne
Don Kollmann
Wisconsin EPS
Database Analyst
Hmm, been spending a bunch of time messing with the export utility this
afternoon, and just fired up email after a couple hours. Looks like
someone else is having the same struggle today :)
Behaves like an Inner Join and DOES NOT export the Vendors with a null
GroupCode.
Other stuff I tried generated run time errors, or duplicated vendors X
every VendGrup, and other useless stuff.
Can anyone tell me how to make it behave like a Left Outer Join ?
Thanks, -Wayne Cox
PS... just to make things more aggravating, Vantage leaves the export
file locked sometimes, so you have to rename it with each try. arrgh!
Wayne,
Go here ---> http://www.progress.com/support/techpapers/query.htm
<http://www.progress.com/support/techpapers/query.htm>
What you will find is the "Engine Crew Monographs" --- probably another
obscure drinking thing within Progress.
These are what you would call "White Papers". Or "Query Documentation for
us dummies ..."
At any rate - it's a first rate bit of documentation JUST about query
strategies and formats.
Hope it helps
Todd Anderson
J. Rubin & Co.
GroupCode.
Thanks, -Wayne Cox
And Don asked:
-Thanks,
WC
