Export/Import Enhanced Quality Configurators
Anyone know if its possible to export and import The EQA based Configurator definitions?
I literally just asked Support this question and received this response. It worked perfectly for me.
You can export and import the inspection plan designs but not the attributes, specifications, or the inspection plan revision.
To import and export the inspection plan design go to the configurator entry screen. If you do not have the configurator license go to inspection plan maintenance and pull up the inspection plan you want to import and export.
Go to the revision tab and click on the configure inspection plan button and it will launch the configurator entry screen. Make sure the Inspection plan ID you want to export is populated in the configurator entry screen. Go to the actions menu and find import/export. Select export. In the export screen select all available options. Click browse and select a location to save the export and enter a file name and click ok. Then when back in the export screen click export.
Once that is done go into the target database and go into configurator entry and select or create the inspection plan you wish to import onto. Go to actions>import export>Import. In the import screen select all options except for approve, click on browse and select the file exported from the other database. Then click import in the import screen.
Please note that if you have attributes linked to your inspection plan inputs the attributes will not carry with the inspection plan design.
