- IDC application imports the document from the watched folder.
- It goes to the classify, Capture, Verify, export and then Completed stage. When Check the status in the batch report it shows the completed status. But the XML and Pdf files are not generated for some of the Batches.
- When I check the Exportclient log (C:\Users\Public\Ancora\ExportClient),
Some of the Batch ID are not received in the Export Client process due to that it is not performing export for those documents.
But it receives some Batch IDs on the Export client services process and it export XML & PDF files properly for those Batches.
We want to know why all the Batch ID are not received on the Export Client Process. (Due to that the XML file and PDF files are not generated for all the imported documents even though the document status shows as Completed)
Export Client Log file
Batch - Report
