Hi,
I want to know if I’m able to use existing BAQ and export to PowerBI?
In PowerBI, I’m able to use Get Data and fill in the SQL Server database and check Import Data Connectivity mode. This allows me to select tables and created the relational data, but I need to re-built all over again.
Is there again to export BAQ to PowerBI?
Yes, you can use the OData feed to connect via their API service. Here is some documentation.
https://epicweb.epicor.com/doc/Docs/Epicor10_RESTServices_v2_102600.pdf
