Excess Stock Provision Report and Slow Moving stocks
Hi there. I am setting up the Excess stock provision report but i do not accurately understand the calculations. In Epicor guides it says the calculation is as follows: ‘The excess provision amount is calculated by comparing the on hand quantity or past consumption of the previous periods. The excess stock provision amount is calculated as a percentage of the extended cost of the excess stock’. However, i do not get the process it follows.
Besides, I have created the same config for excess and slow-moving stocks and the result is the same. What is the difference between them?
Thank you in advance :slight_smile:
Without digging under the covers, Epicare has a few articles that are related to the report KB0041108, KB0122390 Not sure if the second one will be of much help… :person_shrugging:
