Excel Spreadsheet as menu item
How can I add a link to an Excel Spreadsheet in Epicor that is available to everyone? I know I can add a tile to my homepage linked to the Excel spreadsheet, but not what I want. Can I add a menu item in menu maintenance linking to the spreadsheet? Is there another way to do this?
Too easy!
Just add a menu maintenance item as program type: External Process and then paste the shortcut to the spreadsheet in the program box.
It has to be formatted as such “C:\folder\filename.xlsx” etc…
Unsolicited suggestion: I would convert that spreadsheet into a Google Sheet (or online via O365, etc) instead of a local spreadsheet–it will make concurrency that much easier to deal with assuming this isn’t just a read-only file.
Thanks, I tried that, but it would only filter .exe, didn’t know you could paste the path in there. Works great!
