Examples of Direct BO calls with vb.net desired
Thanks Jose,
Found it and used the online converter I saw you pointed out in another post http://www.developerfusion.com/tools/convert/csharp-to-vb
to switch the code.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Tuesday, March 01, 2011 12:42 PM
Subject: Re: [Vantage] Examples of Direct BO calls with vb.net desired
Search the list for an example I sent about 1 month ago or so to someone
else, its pretty simple / self explinatory although In C# not VB but they
transform into eachother easely
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...<mailto:jose%40josecgomez.com>
http://www.josecgomez.com
On Tue, Mar 1, 2011 at 10:26 AM, Waffqle <waffqle@...<mailto:waffqle%40gmail.com>> wrote:
> From customization mode, open the 'Custom Object Explorer'. Click the
> 'Adapter' tab and the 'Get Adapters' button.
> If you expand any adapter and select a method it will show you the code you
> need to call it.
> Note that you may need to add refernces if the adapter you want isn't
> native
> to the form you're working on.
> On Tue, Mar 1, 2011 at 9:44 AM, davidbeberman <dbeberman@...<mailto:dbeberman%40fergusonperf.com>
> >wrote:
> > Hi all,
> > I am looking to find examples in vb.net(if possible) of Direct Business
> > Object calls. We are on 9.0.5.602A at this time and I wish to mimic in
> > customization code the calls done by running a trace.
> > I am familiar with Service Connect but realize from reading many forum
> > entries that coding is more desireable (efficiency/dependability
> factors).
> > Thank you,
> > David Beberman
> > Sr. Business Analyst
> > Ferguson Perforating
> > Providence RI
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
Hi all,
I am looking to find examples in vb.net(if possible) of Direct Business Object calls. We are on 9.0.5.602A at this time and I wish to mimic in customization code the calls done by running a trace.
I am familiar with Service Connect but realize from reading many forum entries that coding is more desireable (efficiency/dependability factors).
Thank you,
David Beberman
Providence RI
dbeberman@...
need to call it.
Note that you may need to add refernces if the adapter you want isn't native
On Tue, Mar 1, 2011 at 9:44 AM, davidbeberman <dbeberman@...>wrote:
> Hi all,
> Thank you,
> David Beberman
> Providence RI
> dbeberman@...
Thank you for your help.
Now the learning curve of setting/passing the correct properties between the calls begins..
I'm familiar with this pain from Service Connect in the past.
-Dave
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Waffqle
Sent: Tuesday, March 01, 2011 10:27 AM
From customization mode, open the 'Custom Object Explorer'. Click the 'Adapter' tab and the 'Get Adapters' button.
If you expand any adapter and select a method it will show you the code you need to call it.
Note that you may need to add refernces if the adapter you want isn't native to the form you're working on.
> Hi all,
> Thank you,
> David Beberman
> Providence RI
> dbeberman@...
I've never used service connect but I'd image that a helpful tool in
both scenarios is the BL tester.
The BL tester works with the actual BO instead of the adapter but it is
helpful in understanding how the adapters work.
Typically, I only use adapters if I need user interaction but if I want
to totally automate with no user interaction then I will use the BO
instead.
Arguably it might be a little more complicated but you have a "finer"
control over the process.
Of David Beberman
Sent: Tuesday, March 01, 2011 10:39 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Examples of Direct BO calls with vb.net desired
the calls begins..
-Dave
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Behalf Of Waffqle
dbeberman@... <mailto:dbeberman%40fergusonperf.com> >wrote:
> Hi all,
factors).
> Thank you,
> David Beberman
> Providence RI
I've seen the BL Tester - there's screenshots of it in the Files section.
It looks like a great tool to get "intimate" with the parameters in and out of a BO.
I believe it is part of the SDK and a costly tool to get.
Am I wrong?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Joe Rojas
Sent: Tuesday, March 01, 2011 10:52 AM
instead.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of David Beberman
To: 'vantage@yahoogroups.com<mailto:%27vantage%40yahoogroups.com>'
the calls begins..
-Dave
jrojas@...<mailto:jrojas%40matsinc.com> | www.matsinc.com<http://www.matsinc.com> Ask us about our clean, green and beautiful matting and flooring
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of Waffqle
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
dbeberman@...<mailto:dbeberman%40fergusonperf.com> <mailto:dbeberman%40fergusonperf.com> >wrote:
> Hi all,
factors).
> Thank you,
> David Beberman
> Providence RI
Yes. :)
All Epicor/Vantage customers get the BL tester for free.
I can find it on my Epicor 9 CD in the Utilities\BL_Tester folder
Of David Beberman
Sent: Tuesday, March 01, 2011 12:01 PM
section.
out of a BO.
Am I wrong?
Behalf Of Joe Rojas
instead.
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf
Of David Beberman
To: 'vantage@yahoogroups.com <mailto:%27vantage%40yahoogroups.com>
the calls begins..
-Dave
jrojas@... <mailto:jrojas%40matsinc.com>
On
Behalf Of Waffqle
> Hi all,
factors).
> Thank you,
> David Beberman
> Providence RI
<http://groups.yahoo.com/group/vantage/files/> <
Joe,
Thanks for the help - so glad I am wrong!
-Dave
Sent: Tuesday, March 01, 2011 12:04 PM
Yes. :)
Of David Beberman
section.
out of a BO.
Am I wrong?
Behalf Of Joe Rojas
instead.
On Behalf
Of David Beberman
To: 'vantage@yahoogroups.com<mailto:%27vantage%40yahoogroups.com> <mailto:%27vantage%40yahoogroups.com>
the calls begins..
-Dave
jrojas@...<mailto:jrojas%40matsinc.com> <mailto:jrojas%40matsinc.com>
On
Behalf Of Waffqle
> Hi all,
factors).
> Thank you,
> David Beberman
> Providence RI
*Jose C Gomez*
*Software Engineer*
E: jose@...
> need to call it.
> native
> >wrote:
> > Hi all,
> factors).
> > Thank you,
> > David Beberman
> > Providence RI
> > dbeberman@...
