Eug - Is it possible to add a field to a Collection?
Hi bw2868bond,
Thanks!
I just got back to this old project.
Your example worked great.
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> Here is even an older example for the Time Phase lookup screen:
> '// Custom VB.NET code for TimePhasForm
> '// Created: 8/22/2007 8:55:46 AM
> Imports System
> Imports System.Data
> Imports System.Diagnostics
> Imports System.Windows.Forms
> Imports System.ComponentModel
> Imports Microsoft.VisualBasic
> Imports Epicor.Mfg.UI
> Imports Epicor.Mfg.UI.FrameWork
> Imports Epicor.Mfg.UI.ExtendedProps
> Imports Epicor.Mfg.UI.FormFunctions
> Imports Epicor.Mfg.UI.Customization
> Imports Epicor.Mfg.UI.Adapters
> Imports Epicor.Mfg.UI.Searches
> Imports Epicor.Mfg.BO
> Module Script
> '// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables' Comments! **
> '// Begin Wizard Added Module Level Variables **
> Private WithEvents edvTimePhas As EpiDataView
> '// End Wizard Added Module Level Variables **
> '// Add Custom Module Level Variables Here **
> Sub InitializeCustomCode()
> '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Variable Intialization' lines **
> '// Begin Wizard Added Variable Intialization
> edvTimePhas = CType(oTrans.EpiDataViews("TimePhas"), EpiDataView)
> '// End Wizard Added Variable Intialization
> '// Begin Custom Method Calls
> If Not (edvTimePhas.dataView.Table.Columns.Contains("ParentPart")) Then
> edvTimePhas.dataView.Table.Columns.Add(new DataColumn("ParentPart"))
> End If
> '// End Custom Method Calls
> End Sub
> Sub DestroyCustomCode()
> '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
> '// Begin Wizard Added Object Disposal
> '// End Wizard Added Object Disposal
> '// Begin Custom Code Disposal
> '// End Custom Code Disposal
> End Sub
> Private Sub edvTimePhas_EpiViewNotification(view As EpiDataView, args As EpiNotifyArgs) Handles edvTimePhas.EpiViewNotification
> '// ** Argument Properties and Uses **
> '// view.dataView(args.Row)("[FieldName]")
> '// args.Row, args.Column, args.Sender, args.NotifyType
> '// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
> If (args.NotifyType = EpiTransaction.NotifyType.Initialize) Then
> If (args.Row > -1) Then
> AddParentPart()
> End If
> End If
> End Sub
> Private Sub AddParentPart()
> For Each dr As DataRow In edvTimePhas.dataView.Table.Rows
> If Not IsDBNull(dr("JobNum")) Then
> dr("ParentPart") = getParentPart(dr("JobNum"))
> End If
> Next
> End Sub
> Private Function getParentPart(ByVal job As String) As String
> Dim parentPart As String
> Dim recordSelected As Boolean
> Dim showSearch As Boolean = False
> Dim whereClause As String = "JobNum = '" + job + "'"
> Dim dsJobInfo As DataSet = SearchFunctions.listLookup(TimePhasForm, "JobAsmSearchAdapter", recordSelected, showSearch, whereClause)
> If recordSelected Then
> parentPart = dsJobInfo.Tables(0).Rows(0)("PartNum").ToString()
> Else
> parentPart = ""
> End If
> Return parentPart
> End Function
> End Module
> --- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@> wrote:
> > > You can add a column to the data view,
> > >but it will be empty until you put data into the column.
> > Do you have any examples you can share?
> > I found one old thread with an example for receipt entry but I'm not having any luck with it.
> > Thanks
> > --- In vantage@yahoogroups.com, "bw2868bond" <bwalker@> wrote:
> > > You can add a column to the data view, but it will be empty until you put data into the column.
> > > The grid will automatically include the added column
> > > > Hi,
> > > > Is it possible to add columns to Collections?
> > > > I am looking at a grid on a form.
> > > > The grid is bound to a native view.
> > > > The field I want to display in the grid isn't listed in the columns collection.
> > > > Thanks
Hi,
--- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@...> wrote:
> Hi,
> Thanks
> > Hi,
> > Thanks
Imports System
Imports System.Data
Module Script
End If
End Sub
End Sub
AddParentPart()
End If
End If
End Sub
End If
Next
End Sub
Else
parentPart = ""
End If
Return parentPart
End Function
End Module
> Thanks
> > > Hi,
> > > Thanks
