Error with Crystal Report after upgrade from Vista 8.03.409C to
Ah, yes, there is an "Epicor" limit on XML size. Technically, there is no
limit on the size of an XML file, but Epicor only can create an XML dataset
up to 50MB, I think. I hit this limit on some BAQ Exports, but a RDD
dataset should never be that large to travel across the wire to the client.
ultrax_tyler
Sent: Tuesday, February 05, 2013 4:05 PM
Subject: [Vantage] Re: Error with Crystal Report after upgrade from Vista
8.03.409C to Epicor 9.05.700C
We currently have an open ticket with Epicor, we get this error with some
built in reports as well, it seems to happen for us when the XML file
reaches a large size 30-50MB. If we rerun the same report but say for a
smaller date range (1 week vs 1 month) then it can fully create the XML
file.
-Tyler
"bryandavis1980" wrote:
> "Unexpected end of file has occurred. The following elements are not
closed: ReportDataSet. Line 869, position 1."
> Hello,
> I am getting the following error above, on one of our main reports and am
in need of some help. The standard built in report pulled up just fine, but
this one is pretty modified with barcodes and such. I did not create the
report to begin with as I am new to working with how Epicor works with
Crystal. I realize that its probably somewhere in the dataset that is
causing issues... I just don't know how to go about fixing it... or really
where to start with this one. Any help would be great!
> Thank you,
> Bryan
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2238 / Virus Database: 2639/5583 - Release Date: 02/05/13
"Unexpected end of file has occurred. The following elements are not closed: ReportDataSet. Line 869, position 1."
Hello,
I am getting the following error above, on one of our main reports and am in need of some help. The standard built in report pulled up just fine, but this one is pretty modified with barcodes and such. I did not create the report to begin with as I am new to working with how Epicor works with Crystal. I realize that its probably somewhere in the dataset that is causing issues... I just don't know how to go about fixing it... or really where to start with this one. Any help would be great!
Thank you,
Bryan
That error is indicative of a bad XML dataset. More than likely the
Customized Report Data Definition is faulty, somehow.
Take a look at the RDD. You may need to recreate the customized version.
bryandavis1980
Sent: Tuesday, February 05, 2013 3:44 PM
Subject: [Vantage] Error with Crystal Report after upgrade from Vista
Hello,
Thank you,
Bryan
We currently have an open ticket with Epicor, we get this error with some built in reports as well, it seems to happen for us when the XML file reaches a large size 30-50MB. If we rerun the same report but say for a smaller date range (1 week vs 1 month) then it can fully create the XML file.
-Tyler
> Hello,
> Thank you,
> Bryan
