Error while updating ShipHead.ShipToNum at CustomerShipmentEntry For
Hi all,
after creating pack slips, there are instance where our sales team change the shipto address of an order.
when they change shipto address at orderentry, we expect it to be updated in shipment entry as well. But, it does not update. as a result, a pack slip is printed with old shipping address leading to wrong delivery location.
so, i have written program -  before printing pack slip, check whether shiphead.shiptonum = orderhed.shiptonum are same . if they are not same, update shiphead.shiptonum = orderhed.shiptonum.
below is program ... Epicor 9.05 700B not allowing me to update.
Private Sub baseToolbarsManager_ToolClick(ByVal sender As Object, ByVal args As Infragistics.Win.UltraWinToolbars.ToolClickEventArgs)
If args.Tool.Key.ToString() Like "Print*" Then
Dim edvShipDtl As EpiDataView = CType(oTrans.EpiDataViews("ShipDtl"), EpiDataView)
 If edvShipDtl.dataView.Count > 0 Then
Dim edvShipHead As EpiDataView = CType(oTrans.EpiDataViews("ShipHead"), EpiDataView)
Dim ShipHeadShipToNum As String = edvShipHead.dataView(edvShipHead.Row)("ShipToNum")
Dim OrderHeadShipToNum As String = chkSOShipToNum(edvShipDtl.dataView(edvShipDtl.Row)("OrderNum")) /*this function brings me the orderhed.shiptonum */
If (ShipHeadShipToNum <> OrderHeadShipToNum) Then
edvShipHead.dataView(edvShipHead.Row).BeginEdit()
edvShipHead.dataView(edvShipHead.Row)("ShipToNum") = OrderHeadShipToNum
edvShipHead.dataView(edvShipHead.Row).EndEdit()
oTrans.update()
oTrans.Refresh()
End If
End If
End If
End Sub
Private Function chkSOShipToNum(ByVal orderNum As Integer) as String
Dim SOShipToNum as String
Try
' Declare and Initialize EpiDataView Variables
' Declare and create an instance of the Adapter.
Dim adapterSalesOrder As SalesOrderAdapter = New SalesOrderAdapter(Script.oTrans)
adapterSalesOrder.BOConnect()
adapterSalesOrder.clearData()
' Declare and Initialize Variables
' Call Adapter method
Dim res_SalesOrder As Boolean = adapterSalesOrder.GetByID(orderNum)
If res_SalesOrder = True Then
SOShipToNum = adapterSalesOrder.SalesOrderData.OrderHed(0).ShipToNum
Else
MessageBox.Show("SalesOrder Missing!")
End If
' Cleanup Adapter Reference
adapterSalesOrder.Dispose
Catch ex As System.Exception
ExceptionBox.Show(ex)
End Try
Return SOShipToNum
End Function
any help much appreciated !!
Reported to Epicor support... its been 3 weeks, no update from them till now!
