Error while setup application server Kinetic 11.2
any hint about the below error while I add the application server and try to connect:
System.Net.Http.HttpRequestException: An error occurred while sending the request. —> System.Net.WebException: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. —> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
at System.Net.TlsStream.EndWrite(IAsyncResult asyncResult)
at System.Net.PooledStream.EndWrite(IAsyncResult asyncResult)
at System.Net.ConnectStream.WriteHeadersCallback(IAsyncResult ar)
— End of inner exception stack trace —
at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context)
at System.Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar)
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Microsoft.Extensions.Http.Logging.LoggingHttpMessageHandler.d__5.MoveNext()
— End of stack trace from previous location where exception was thrown —
at Microsoft.Extensions.Http.Logging.LoggingScopeHttpMessageHandler.d__5.MoveNext()
at Ice.Cloud.ProxyBase`1.d__60.MoveNext()
at Epicor.Utilities.AsyncHelper.RunSync[TResult](Func`1 method)
at Ice.Cloud.ProxyBase`1.Execute(String methodName, RestValueSerializerBase serializer, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut)
at Ice.Cloud.ProxyBase`1.<>c__DisplayClass58_0.b__0(Context _)
at Polly.Policy`1.<>c__DisplayClass32_0.b__0(Context ctx, CancellationToken ct)
at Polly.Retry.RetryEngine.Implementation[TResult](Func3 action, Context context, CancellationToken cancellationToken, IEnumerable1 shouldRetryExceptionPredicates, IEnumerable1 shouldRetryResultPredicates, Func1 policyStateFactory)
at Polly.RetryTResultSyntax.<>c__DisplayClass12_01.<WaitAndRetry>b__0(Func3 action, Context context, CancellationToken cancellationToken)
at Polly.Policy1.ExecuteInternal(Func3 action, Context context, CancellationToken cancellationToken)
at Polly.Policy1.Execute(Func3 action, Context context, CancellationToken cancellationToken)
at Polly.Policy1.Execute(Func2 action, Context context)
at Ice.Cloud.ProxyBase`1.CallWithCommunicationFailureRetry(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, RestRpcValueSerializer serializer)
at Ice.Cloud.ProxyBase`1.CallWithMultistepBpmHandling(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Ice.Cloud.ProxyBase`1.Call(String methodName, ProxyValuesIn valuesIn, ProxyValuesOut valuesOut, Boolean useSparseCopy)
at Ice.Proxy.BO.UserFileImpl.IsPasswordExpired(String userID, Int32& graceCount)
at Epicor.Mfg.Administration.ServerManagement.ApplicationServerManager.Forms.NewSessionForm.BackgroundWorker_DoWork(Object sender, DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
@Gendy This thread might have clues. What kind of cert do you have on the app server?
@gpayne Here are the certificates available on the server and we are installing both the application and database on one server.
A quick google of that error indicates it could be an issue with the self signed not being also in the trusted root folder. I think the friendly name also has to match the server name.
