Error when trying to delete a part
I am receiving the following error when attempting to delete a part. I don’t have any BPMs running, and there is nothing in the customization stopping it.
Any ideas on what may be causing this error?
## System Information ##
Form Name: Part Maintenance
Customization Name: PartEntryCust
Menu ID: MRMT1010
Software Version: 10.2.700.33
Server Side Exception
BPM runtime caught an unexpected exception of 'TargetException' type.
See more info in the Inner Exception section of Exception Details.
## Error Detail ##
##!Description:##!  BPM runtime caught an unexpected exception of 'TargetException' type.
##!Program:##!  CommonLanguageRuntimeLibrary
##!Method:##!  CheckConsistency
##!Original Exception Type:##!  TargetException
##!Framework Method:##!  A001_CustomCodeAction
##!Framework Line Number:##!  0
##!Framework Column Number:##!  0
##!Framework Source:##!  A001_CustomCodeAction at offset 833 in file:line:column <filename unknown>:0:0
## Client Stack Trace ##
   at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
   at Erp.Proxy.BO.PartImpl.Update(PartDataSet ds)
   at Erp.Adapters.PartAdapter.OnDelete()
   at Ice.Lib.Framework.EpiBaseAdapter.Delete(DataRow dr)
   at Erp.UI.App.PartEntry.PartTransaction.AdapterDelete(DataRow dr)
   at Erp.UI.App.PartEntry.PartTransaction.Delete()
   at Erp.UI.App.PartEntry.PartForm.OnClickDelete()
   at Ice.Lib.Framework.EpiBaseForm.handleToolClickInternal(String tKey, ToolClickEventArgs ea)
   at Ice.Lib.Framework.EpiBaseForm.handleToolClick(String tKey, ToolClickEventArgs ea)
## Inner Exception ##
Non-static method requires a target.
Let’s see the code in the customization.
Well, it turns out it was a BPM causing the error after all. Missed it on the first round. Disabled the BPM and was able to delete the parts.
