Running 10.1.400.19 and am getitng this error when trying to create an report:
Server Error in ‘/Reports’ Application.
The resource cannot be found.
Description: HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly.
Yes, when i am in BAQ Designer and I go tto Actions–>Design SSRS it give me the error I posted. AS of now, I am not creating anything really. Had a bad report issue about amonth ago that @aidacra helped with and since then I ahve not been able to create an SSRS. So something is off.
@Alexandre_Pothier and @Mario.Cortes I am still on the old 10.1.400.19. I have 10.2.200 in my test and it is not there. I was told the fix could be in that something is corrupt in the SQL server for SSRS and a patch would fix the issue. So i will be trying that soon.
I could be doing it old-school, back how I learned to do it when BAQ Reports were “new” and only supported Crystal. (insert old-man joke here) My process is I enter the into into the Detail tab of BAQ Report Designer then Actions - Test Report Form and do a print preview. This makes a blank report then previews it on screen. Then I use my browser to connect to the SSRS Server and drill down into the Custom Reports folder and edit the report.
Have you tried “Download SSRS Report”? I haven’t but could be faster than my above way.
@ckrusen, I just use the Detail tab I’ve never had to use the filters or sorts tabs as that’s done in the BAQ or report. Our BAQReports are typically for auto-email reports ran overnight, so no need for the features of those tabs.
Ah, understood and I’ve not used them either. We’re on 10.2 and don’t even have “Design SSRS Report” option, I believe it’s replaced with “Download SSRS Report” there is also a 'Upload SSRS Report" as that is what is place on the menu.
If the Download/Upload will also get the report’s sub-reports that’d be so much easier than using the one-at-a-time browser method.
