Error when launching reporting menu item from MES
We have a number of custom buttons in MES for launching forms, using C# code tied to the menu item ID. This is the first time I have added a menu item that is of the “report” style, and I am getting the following error:
Application Error
Exception caught in: Erp.Mfg.UIRpt.PCIDContectsReportEntry
Error Detail
Message: Unable to cast object of type 'System.String' to type 'System.Collections.Hashtable'.
Program: Erp.Mfg.UIRpt.PCIDContectsReportEntry.dll
Method: OnFormLoaded
Client Stack Trace
   at Erp.Mfg.UI.Rpt.PCIDContectsReportEntry.ReportForm.OnFormLoaded()
   at Ice.Lib.Framework.EpiBaseForm.formLoaded()
The report still launches after clicking OK, but I am wondering if this has something to do with the parameters getting passed in on form load. I have searched through the trace and not sure where to go.
Can you post the code? I think you are on the right track in looking at how you are passing the parameters.
I’m not actively passing any parameters…but maybe I need to, or modify what is being passed by default?
// Custom code for MESMenu
// Created: 10/21/2019 11:49:48 AM
using System;
using System.ComponentModel;
using System.Collections.Generic;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
		private EpiDataView edvEmpBasic;
		EpiButton btnPCIDContentsRep;
		btnPCIDContentsRep = (EpiButton)csm. GetNativeControlReference("6dae650b-8ea9-48e2-a4d7-468ce0216d83");
// "1fc1c201-c051-45c6-9d55-612d0e9199c8"
			this.edvEmpBasic = ((EpiDataView)(this.oTrans.EpiDataViews["EmpBasic"]));
			this.edvEmpBasic.EpiViewNotification += new EpiViewNotification(this.edvEmpBasic_EpiViewNotification);
			this.btnPCIDContentsRep.Click += new System.EventHandler(this.btnPCIDContentsRep_Click);
			this.edvEmpBasic.EpiViewNotification -= new EpiViewNotification(this.edvEmpBasic_EpiViewNotification);
			this.edvEmpBasic = null;
		// Begin Custom Code Disposal
		// End Custom Code Disposal
			this.btnPCIDContentsRep.Click -= new System.EventHandler(this.btnPCIDContentsRep_Click);
	private void MESMenu_Load(object sender, EventArgs args)
			// Add Event Handler Code
				btnPCIDContentsRep.ReadOnly = true;
	private void btnPCIDContentsRep_Click(object sender, System.EventArgs args)
		ProcessCaller.LaunchForm(this.oTrans, "AMRP1000");
	private void edvEmpBasic_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
		// view.dataView[args.Row]["FieldName"]
		// args.Row, args.Column, args.Sender, args.NotifyType
		// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
		if ((args.NotifyType == EpiTransaction.NotifyType.Initialize))
			if ((args.Row > -1))
				btnPCIDContentsRep.ReadOnly = false;
			else
I was able to reproduce the error. Try adding a blank launch form options and passing it in the call. Killed the error for me.
LaunchFormOptions lfo = new LaunchFormOptions();
ProcessCaller.LaunchForm(this.oTrans, “Erp.Mfg.UIRpt.PCIDContectsReportEntry”,lfo);
(insert your menuID)
(Sorry, this text did not want to get formatted)
Not sure exactly why, but something related to the launch form options being a hashtable. Maybe a blank string was being passed instead, not sure. Maybe someone else can shed some light on why this is happening.
Adam, thank you so much! I have set up LFO’s before but didn’t even think of that. Much appreciated.
No problem! Lucky (educated) guess on my part.
