Error running Epicor client first time
We have a third party that will be accessing our Epicor servers in Azure from PCs connected through a ZScaler tunnel. We’ve installed the Epicor client from the front end server, however when we try to run the client as an Administrator on the PC we get the follwoing error:
Application: Epicor.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
at Epicor.ServiceModel.Trace.ClientTracing.UserTracer…cctor()
Exception Info: System.TypeInitializationException
at Epicor.ServiceModel.Trace.ClientTracing.UserTracer.get_DialogException()
at Ice.Lib.Epicor.Main(System.String[])
Faulting application name: Epicor.exe, version: 3.2.700.0, time stamp: 0x5f4d5151
Faulting module name: KERNELBASE.dll, version: 10.0.19041.2006, time stamp: 0xa5d20e5c
Exception code: 0xe0434352
Fault offset: 0x0012cc12
Faulting process id: 0x2e1c
Faulting application start time: 0x01d8d9c23d82a7d3
Faulting application path: C:\Epicor\ICE3.2.700.0Client\Client\Epicor.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: 9fbb2cee-a8d4-4cab-868e-e727750793bf
Faulting package full name:
Faulting package-relative application ID:
I’m not a sys admin, first time we’re trying this scenario. Anyone have an idea why this isn’t working?
We are having the same issue after upgrading to 11.2.300 . Though this is only happening on one of our servers. Did you manage to figure this one out?
Welcome to the cmmunity, @Alex_Bryan ! Since this was a system outside our domain, we switched to using a Virtual Desktop for them to get around the issue. Epicor Support should be able to help you with this since you’re on the newest version.
Try to install the latest version of .Net Framework and check.
Try deleting any folders located within:
%appdata%\..\Local\Epicor
%appdata%\..\Roaming\Microsoft\CLR Security Config
%AllUsersProfile%\Epicor
https://epiccare.epicor.com/epiccare?id=epiccare_kb_article&sys_id=a9ce72741bc761d0ca66eb13b24bcbad
If that doesn’t work, try Uninstalling .NET Framework and Installing it again, do not use the Repair option.
It should work fine with ZScaler, it all depends if you use ZPA VPN and have the IPs whitelisted, or you just use ZScaler.
More related posts:
https://www.epiusers.help/search?q=0xe0434352
