I get this error when I open Epicor. I can click past it and get into Epicor and everything seems to be OK, but I am curious what this could be about.
Application Error
Exception caught in: System.Data
Error Detail
Message: Failed to enable constraints. One or more rows contain values violating non-null, unique, or foreign-key constraints.
Program: System.Data.dll
Method: EnableConstraints
Client Stack Trace
at System.Data.DataSet.EnableConstraints()
at System.Data.DataSet.set_EnforceConstraints(Boolean value)
at System.Data.Merger.MergeDataSet(DataSet source)
at System.Data.DataSet.Merge(DataSet dataSet, Boolean preserveChanges, MissingSchemaAction missingSchemaAction)
at System.Data.DataSet.Merge(DataSet dataSet)
at Ice.Bpm.Context.CallContextManager.InitCall(ContextDataSet contextData)
at Ice.Proxy.BO.GenXDataImpl.StoreData(GenXDataDataSet ds)
at Ice.Lib.Framework.GenXObject.handleChunkAndSave(Boolean doCompression, String company, String productID, String typeCode, String cgcCode, String key1, String key2, String key3, String description, String comment, String version, Boolean layerWIP, String data)
at Ice.Lib.Framework.GenXObject.ChunkNSaveStringByID(String company, String productID, String typeCode, String cgcCode, String key1, String key2, String key3, String description, String comment, String version, Boolean layerWIP, String data)
at Ice.Lib.Framework.GenXObject.ChunkNSaveStringByID(String company, String productID, String typeCode, String key1, String key2, String key3, String description, String comment, String version, Boolean layerWIP, String data)
at Ice.Lib.Framework.FormFunctions.ChunkNSaveStringByID(Session s, String company, String productID, String typeCode, String key1, String key2, String key3, String description, String comment, String version, Boolean layerWIP, String data)
at Ice.Lib.Framework.FormFunctions.ChunkNSaveStringByID(Object sender, String company, String productID, String typeCode, String key1, String key2, String key3, String description, String comment, String version, Boolean layerWIP, String data)
