Hi, I am getting the error below. I’d like to know if it is possible to find which rule is causing the error, from the line mentioned in report. Where is the file that this is referring to (the 'Line 52, 94, 98 etc.)
Business Layer Exception
Exception was found for Rule Key: /o0080/m0920
System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseDecimal(String value, NumberStyles options, NumberFormatInfo numfmt)
at System.Convert.ToDecimal(String value)
at Erp.Internal.Cfg._PodConfiguratorV10.TEST13._PodV10A_RuleEngine.RuleSet89_Rule1_Action174(RuleArgs args)
at Erp.Internal.PC.Configuration.RuleEngine.RuleCommands.RuleActions.ExecuteExpressionCmd.Execute(RuleArgs args) in C:_Releases\ERP\UD10.2.400.15\Source\Server\Internal\PC\Configuration\RuleEngine\RuleCommands\RuleActions\ExecuteExpressionCmd.cs:line 52
at Erp.Internal.PC.Configuration.RuleEngine.PcRule1.ExecuteActions(TRuleArgs args) in C:\_Releases\ERP\UD10.2.400.15\Source\Server\Internal\PC\Configuration\RuleEngine\PcRule.cs:line 94 at Erp.Internal.PC.Configuration.RuleEngine.PcRuleSet
1.ExecuteRules(TRuleArgs args) in C:_Releases\ERP\UD10.2.400.15\Source\Server\Internal\PC\Configuration\RuleEngine\PcRuleSet.cs:line 98
at Erp.Internal.PC.Configuration.RuleEngine.RuleEngine`2.Invoke(String ruleKey, TRuleArgs args) in C:_Releases\ERP\UD10.2.400.15\Source\Server\Internal\PC\Configuration\RuleEngine\RuleEngine.cs:line 200
Error Detail
Description: Exception was found for Rule Key: /o0080/m0920
Program: Erp.Internal.PC.Configuration.dll
Method: Invoke
Line Number: 200
Column Number: 25
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.ConfigurationRuntimeImpl.ProcessKeepWhen(ConfigurationSequenceDataSet configurationSequenceDS, ConfigurationRuntimeDataSet configRuntimeDS, PcValueDataSet pcValueDS, String parAltMethod, Boolean checkNextCfg, Boolean& enableNextPage)
at Erp.Adapters.ConfigurationRuntimeAdapter.ProcessKeepWhen(PcValueDataSet pcValueDS, String parAltMetthod, Boolean checkNextCfg, Boolean& enableNextPage)
Any help would be greatly appreciated.
