Any advice thoughts here appreciated. Getting error as it seems that I cannot grab the csm during runtime or I am doing something wrong here.
Below code compliles fine in customze tracker view, but deploy dashboard > test application errors out on attempting to complie.
On test application:
--------compile errors------------
Error: CS1061 - line 149 (148) - ‘Ice.UI.App.dsbVendXRef.V_qSupplier4DB_1ViewDetailPanel1.V_qSupplier4DB_1ViewDetailPanel1CodeBehind’ does not contain a definition for ‘csm’ and no extension method ‘csm’ accepting a first argument of type ‘Ice.UI.App.dsbVendXRef.V_qSupplier4DB_1ViewDetailPanel1.V_qSupplier4DB_1ViewDetailPanel1CodeBehind’ could be found (are you missing a using directive or an assembly reference?)
** Compile Failed. **
// Custom code for 2f9f0ffe-3401-4764-8339-bd8d07fdf7ce
// Created: 6/4/2020 10:52:55 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using System.Reflection;
public static class Script
private static EpiTextBox txtVendor;
public static void InitializeCustomCode()
txtVendor = (EpiTextBox)Script.csm.GetNativeControlReference("5286af6d-b5e0-4434-a70c-35d11e974889");
Script.btnRefresh.Click += new System.EventHandler(Script.btnRefresh_Click);
Script.txtVendor.Leave += new System.EventHandler(Script.txtVendor_Leave);
Script.txtVendor.Enter += new System.EventHandler(Script.txtVendor_Enter);
public static void DestroyCustomCode()
Script.btnRefresh.Click -= new System.EventHandler(Script.btnRefresh_Click);
// Begin Custom Code Disposal
// End Custom Code Disposal
Script.txtVendor.Leave -= new System.EventHandler(Script.txtVendor_Leave);
Script.txtVendor.Enter -= new System.EventHandler(Script.txtVendor_Enter);
private static void btnRefresh_Click(object sender, System.EventArgs args)
// Plan to have button to refresh grids below here
private static void txtVendor_Leave(object sender, System.EventArgs args)
MessageBox.Show("txtVendor_Name_Leave"); //For Testing. Would like to refresh query grid upon leaving this starts with box.
private static void txtVendor_Enter(object sender, System.EventArgs args)
MessageBox.Show("txtVendor_Name_Enter"); //For Testing.
// txtVendor GUID: 5286af6d-b5e0-4434-a70c-35d11e974889
