Error message when running RB report from Vantage
Troy,
Problem solved! Thanks for pointing me in the right direction!
Lonnie
--- In vantage@y..., "Troy Funte" <tfunte@e...> wrote:
> Hi Lonnie,
> Just got home from church and checked my email. We had the same
problem after converting to 5.0. There are a couple possibilites for
you from EraNet. #1 is for if this affects ALL workstations. #2 and
#3 are for specific workstations. I ended up doing #1 below, and
then I had to also reinstall progress on a few workstations as well
(for some reason). Hope this helps.
> Troy Funte
> Liberty Electronics
> #1
> Page: 1229MPS
> Summary: RB, unable to open convmap with custom report links
> AnswerBook: Vantage ChangeRequests
> XA 5.00
> Problem: Opening custom report links in Vantage generates error:
> Resolution: Vantage 5.00 no longer the Vantage.ini to connect to
report builder
> Because the report builder.vtg and edit the "other parameters" no
longer uses 'Basekey ini" it now uses the Progress.ini by default.
> Report builder.vtg
> [Vantage Startup]
> Executable=V:\Progress\bin\prorb32.exe
> Database=V:\Vantage\db\vantage
> IniFile=V:\Vantage\Vantage.ini
> ParameterFile=V:\Vantage\db\Vantage.pf
> ConnectOptions=-N TCP -H mntech -S epic50
> TempDirectory=C:\Vntg50
> StartupProcedure=
> OtherParameters=
> --> NOTE: the 'OtherParameters=' line is blanked out
> Apparently this causes no problem with the database engine because
it uses the registry so. You will also need to edit the
progress\Bin\progress.ini to reference the mapped drive path instead
of the physical drive path.
> After editing the startup section it should look something like
this:
> Progress.ini
> [Startup]
> V6Display=no
> ;ImmediateDisplay=yes
> ;MultitaskingInterval=100
> DefaultFont=MS Sans Serif, size=8
> DefaultFixedFont=Courier New, size=8
> DLC=V:\progress
> Use-3D-Size=Yes
> PROBUILD=V:\progress\PROBUILD
PROPATH=.,V:\progress\gui,V:\progress,V:\progress\bin,V:\progress\PROB
UILD\EUCAPP\EUC.PL,V:\progress\PROBUILD\EUCAPP
> UseSourceEditor=yes
> ;EditorConfigPath=V:\prowork\proedit
> Where V is a mapped drive.
> Pay special attention to the DLC path, that it says V:\progress,
NOT V:\epic50\progress
> #2
> Page: 312.1116MPS
> Summary: PG - Unable to open convmap file v:\dlc\convmap.cp (98)
> PROBLEM DESCRIPTION:
> Error 'Unable to open convmap file v:\dlc\convmap.cp (98)' only
> getting from one worksation.
> No local copies of vantage.ini, no unique files vntgwork. This is a
report builder report being run from within vantage. They have
vantage mapped to the u: drive. Version 3.00.613. Can access vantage,
all vtgs mapped to u:. win95, on nt. For some reason the report
appears to be looking in the V:\dlc for the convmap. Customer has the
Convmap.cp file in the U:\dlc directory.
> PROBLEM RESOLUTION: Suggestion would be to have them remove and
reinstall the Progress Shared Network client on the problem
workstation.
> Report Builder would be using the windows registry DLC environment
variable. Possibly this is set to v:\dlc on this workstation.
> #3
> Make sure there are no old DLC variables being set in the
autoexec.bat file of any workstation.
> Troy Funte
> Liberty Electronics
> From: Lonnie Drew
> To: vantage@y...
> Sent: Sunday, July 08, 2001 1:44 PM
> Subject: [Vantage] Error message when running RB report from
Vantage
> Is anyone out there this Sunday?
> We've just upgraded to 5.0 and getting an error whenever trying
to
> run a Report Builder report from the Vantage menu, "Unable to
open
> convmap file, 'd:\epic50\progress\convmap.cp' ".
> Same error when selecting the Report Builder button from the
Desktop
> menu bar and running a report.
> No error when running a Report Builder report from the windows
> desktop icon.
> No problems on the training server, so I've obviously missed
> something on the live side.
> Any help appreciated!
> Lonnie Drew
> lonniedrew@c...
> To access the Files Section of our Yahoo!Group for Report Builder
and Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have
already linked your email address to a yahoo id to enable access.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
We've just upgraded to 5.0 and getting an error whenever trying to
run a Report Builder report from the Vantage menu, "Unable to open
Same error when selecting the Report Builder button from the Desktop
desktop icon.
Lonnie Drew
lonniedrew@...
Hi Lonnie,
Just got home from church and checked my email. We had the same problem after converting to 5.0. There are a couple possibilites for you from EraNet. #1 is for if this affects ALL workstations. #2 and #3 are for specific workstations. I ended up doing #1 below, and then I had to also reinstall progress on a few workstations as well (for some reason). Hope this helps.
Troy Funte
Liberty Electronics
#1
Page: 1229MPS
XA 5.00
Problem: Opening custom report links in Vantage generates error: unable to open convmap
Resolution: Vantage 5.00 no longer the Vantage.ini to connect to report builder
Because the report builder.vtg and edit the "other parameters" no longer uses 'Basekey ini" it now uses the Progress.ini by default.
Report builder.vtg
[Vantage Startup]
StartupProcedure=
OtherParameters=
Apparently this causes no problem with the database engine because it uses the registry so. You will also need to edit the progress\Bin\progress.ini to reference the mapped drive path instead of the physical drive path.
After editing the startup section it should look something like this:
Progress.ini
[Startup]
V6Display=no
DLC=V:\progress
Use-3D-Size=Yes
PROPATH=.,V:\progress\gui,V:\progress,V:\progress\bin,V:\progress\PROBUILD\EUCAPP\EUC.PL,V:\progress\PROBUILD\EUCAPP
UseSourceEditor=yes
Pay special attention to the DLC path, that it says V:\progress, NOT V:\epic50\progress
#2
Page: 312.1116MPS
No local copies of vantage.ini, no unique files vntgwork. This is a report builder report being run from within vantage. They have vantage mapped to the u: drive. Version 3.00.613. Can access vantage, all vtgs mapped to u:. win95, on nt. For some reason the report appears to be looking in the V:\dlc for the convmap. Customer has the Convmap.cp file in the U:\dlc directory.
PROBLEM RESOLUTION: Suggestion would be to have them remove and reinstall the Progress Shared Network client on the problem workstation.
Report Builder would be using the windows registry DLC environment variable. Possibly this is set to v:\dlc on this workstation.
#3
Make sure there are no old DLC variables being set in the autoexec.bat file of any workstation.
Troy Funte
Liberty Electronics
Subject: [Vantage] Error message when running RB report from Vantage
desktop icon.
Lonnie Drew
lonniedrew@...
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
