Finally installed a test server APP SERVER 10.1.400 with DB on remote server in a clustered system with Hyper-V. These machines are running Windows 2012R2 with SQL SRV 2014.
Now after successfully deploying and starting the APP SERVER, an error message is generated as follows:
<<BEGIN
Not Connected.
Application Server version has not been verified. Review the Error Message below to troubleshoot your connection issue. It may indicate you need to manually install a newer version of the Administration Console to connect or that it is not supported.
Error Message:
The requested service, 'net.tcp://epicor-app-a.example.local/ERP101400/Ice/BO/UserFile.svc' could not be activated. See the server's diagnostic trace logs for more information.
Any help would be greatly appreciated. This is a clean install. All prerequisites pass.
Thanks!
On Saturday, March 12, 2016, sanfranc415@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p><span>Finally installed a test server APP SERVER 10.1.400 with DB on remote server in a clustered system with Hyper-V.  These machines are running Windows 2012R2 with SQL SRV 2014.</span></p><p><span><br></span></p><p><span>Now after successfully deploying and starting the APP SERVER, an error message is generated as follows:</span></p><p><br></p><p><<BEGIN</p><p>Not Connected.</p><p><br></p><p>Application Server version has not been verified. Review the Error Message below to troubleshoot your connection issue. It may indicate you need to manually install a newer version of the Administration Console to connect or that it is not supported.</p><p><br></p><p>Error Message:</p><p>The requested service, 'net.tcp://epicor-app-a.example.local/ERP101400/Ice/BO/UserFile.svc' could not be activated. See the server's diagnostic trace logs for more information.</p><div><br></div><div>END>></div><p><br></p><p>Any help would be greatly appreciated. This is a clean install. All prerequisites pass.</p><p><br></p><p>Thanks! </p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
Jose C GomezSoftware Engineer
T: 904.469.1524 mobile
