Error EntityException
i do a post processing for my create Order Post and when i try to create my quote i got this message error for this code. Someone know what it is?
foreach (var Dtl in Db.QuoteDtl)
var Company = Dtl.Company;
var QuoteNum = Dtl.QuoteNum;
var QuoteLine = Dtl.QuoteLine;
var reference = Db.OrderDtl.Where(p => p.Company == Session.CompanyID && p.QuoteNum == QuoteNum && p.QuoteLine == QuoteLine).Select(x=> x.Reference).FirstOrDefault();
if (reference != null)
    reference = Dtl.Number09.ToString("0,000");
var quoteNum = Db.OrderDtl.Where(o => o.Company == Session.CompanyID && o.OrderNum == orderNum).Select(x => x.QuoteNum).FirstOrDefault();
if(quoteNum != null)
var quote = Db.QuoteHed.Where(q => q.Company == Session.CompanyID && q.QuoteNum == quoteNum).Select(x => new {x.UserChar1,}).FirstOrDefault();
if(quote != null)
//UD fields to copy to SO from Quote BldgType
using(var txScope = IceContext.CreateDefaultTransactionScope())
var order = Db.OrderHed.Where(o => o.Company == Session.CompanyID && o.OrderNum == orderNum).FirstOrDefault();
  order.UserChar1 = quote.UserChar1;
  Db.Validate();
  txScope.Complete();
System Information
AppServer Connection: http://KINETICAPP.ezeflow.local/KineticTest
Form Name: Opportunity/Quote Entry v1.5
Customization Name: Ezeflow_ECS_1.6
Menu ID: EQMT2010
Software Version: 11.1.200.0
Server Side Exception
BPM runtime caught an unexpected exception of ‘EntityException’ type.
See more info in the Inner Exception section of Exception Details.
Error Detail
##!Correlation ID:##! a80cf0c1-cd78-466c-9524-a4ae4467408d
##!Description:##! BPM runtime caught an unexpected exception of ‘EntityException’ type.
##!Inner Exception:##! The partner transaction manager has disabled its support for remote/network transactions. (Exception from HRESULT: 0x8004D025)
##!Program:##! EntityFramework.dll
##!Method:##! EnlistTransaction
##!Original Exception Type:##! EntityException
##!Framework Method:##! A001_CustomCodeAction
##!Framework Line Number:##! 0
##!Framework Column Number:##! 0
##!Framework Source:##! A001_CustomCodeAction at offset 3662 in file:line:column :0:0
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.QuoteImpl.CreateOrder(QuoteDataSet ds, Int32& orderNum, String& warningMessage)
at Erp.Adapters.QuoteAdapter.CreateOrder(Int32& orderNum, String& warningMessage)
Inner Exception
The underlying provider failed on EnlistTransaction.
Inner Exception
Inner Exception
Is that the entire code?
Why are you going through all records in the QuoteDtl table?
Where are you defining orderNum?
Before updating a record inside a transaction you should use the UpdLock hint to lock the record.
Can you try a simple BPM that only creates a TransactionScope, make a small change and complete it? To rule out if something else in the code is causing the error.
