Error CS1061 in Custom Code BPM
Hi. I am trying to setup a BPM to email users when a shipment is made. Below is the code that I have, however, I am getting a CS1061 error when I Check Syntax. If I remove the Plant table and join, the syntax runs fine.
The Plant table and Plant field are both legitimate tables/fields. Can anyone help me and tell me what I am doing wrong with the Plant table? Any and all help would be greatly appreciated!
Below is the code that I have:
var rows = (from a in Db.TFShipDtl
             join b in Db.TFShipHead on
                  new {a.Company, a.PackNum} equals
                  new {b.Company, b.PackNum}
             join c in Db.Plant on
                  new {b.Company, b.ToPlant} equals
                  new {c.Company, c.Plant}
             join d in Db.ShipVia on
                  new {b.ShipViaCode} equals
                  new {d.ShipViaCode}
                where
                   b.Shipped == true
  select new {a.TFOrdNum, a.TFOrdLine,a.OurStockShippedQty, a.PartNum, a.LineDesc, b.TrackingNumber, b.ShipDate, b.PackNum,  d.Description, d.TrackingNumPlaceHolder, d.TrackingURL} );
Thanks!
Laura
The variable names need to match.
Change it to:
    new {b.Company, plant = b.ToPlant} equals
    new {c.Company, plant = c.Plant}
I think in the EF table Db.Plant the field is named Plant1
Confirmed with other posts here …
We really need better “intellisense” in the Kinetic code editors
Yep the other one like this I always run into is FOB.FOB
