Error CS0019: Operator '<=' cannot be applied to operands of type 'decimal' and 'double'
Hi all!
This is my first time here and this is my first post.
I’m new in the Epicor world so please, let me know if my topic here is unclear!
I ran into an issue while modifying a BAQ embedded into a BPM.
The BPM is blocking users from confirming a PO when there are lines where the price is at zero. (table: PODetail / field: DocExtCost (type: decimal))
The embedded BAQ has a “constant” criteria filtering lines equal to 0, and it works just fine.
I now have to also filters lines who are equal or less to 0.01.
When I’m trying to save that modification, Epicor pops me that error message:
Error CS0019: Operator ‘<=’ cannot be applied to operands of type ‘decimal’ and ‘double’
The BAQ interface here is pretty limited, and it seems that I cannot create calculated fields…
Is there a way or any other strategy I could use for getting what I want?
Let me know if you need any other details!
Thanks in advance for your help :slight_smile:
Are you typing <= 0.01?
If so, then change it to <= 0.01M
Simple as that?!
Works like a charm!
Thanks a lot sir :slight_smile:
This is neat. I have not heard about adding the M like you did. What does it do?
From MS site [Floating-point numeric types - C# reference | Microsoft Learn]
So in the query designer in a BPM the literal without a suffix is a double, but the field being compared to is a decimal. Just by adding the “M” at the end treats both of the comparators as decimal.
