anyone know what this error means?
Application Error
Error Detail
Message: The cast to value type ‘System.Guid’ failed because the materialized value is null. Either the result type’s generic parameter or the query must use a nullable type.
Program: Epicor.ServiceModel.dll
Method: ShouldRethrowNonRetryableException
Client Stack Trace
at System.Data.Entity.Core.Common.Internal.Materialization.Shaper.ErrorHandlingValueReader1.GetValue(DbDataReader reader, Int32 ordinal) at lambda_method(Closure , Shaper ) at System.Data.Entity.Core.Common.Internal.Materialization.Coordinator
1.ReadNextElement(Shaper shaper)
at System.Data.Entity.Core.Common.Internal.Materialization.Shaper1.SimpleEnumerator.MoveNext() at System.Linq.Enumerable.Single[TSource](IEnumerable
1 source)
at System.Data.Entity.Core.Objects.CompiledQuery.ExecuteQuery[TResult](ObjectContext context, Object[] parameterValues)
at System.Data.Entity.Core.Objects.CompiledQuery.Invoke[TArg0,TArg1,TArg2,TArg3,TArg4,TArg5,TResult](TArg0 arg0, TArg1 arg1, TArg2 arg2, TArg3 arg3, TArg4 arg4, TArg5 arg5)
at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass37_17.<Compile>b__3(TContext c, Func
7 query) in C:_Releases\ICE\ICE3.2.200.6\Source\Framework\Epicor.System\Data\DBExpressionCompiler.Generated.cs:line 1207
at Epicor.Data.DBExpressionCompiler.GetResult[TContext,TQuery,TResult](Func3 executeQuery, Cache cacheSetting, TContext dataContext, TQuery query) in C:\_Releases\ICE\ICE3.2.200.6\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 447 at Epicor.Data.DBExpressionCompiler.InvokeSingle[TContext,TQuery,TResult](Expression expression, Cache currentCacheSetting, Boolean cacheQuery, TContext dataContext, Func
2 getDataCacheKey, Func2 compileQuery, Func
3 executeQuery) in C:_Releases\ICE\ICE3.2.200.6\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 306
at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass37_07.<Compile>b__0(TContext context, TArg1 arg1, TArg2 arg2, TArg3 arg3, TArg4 arg4, TArg5 arg5) in C:\_Releases\ICE\ICE3.2.200.6\Source\Framework\Epicor.System\Data\DBExpressionCompiler.Generated.cs:line 1200 at Erp.Internal.BM.BMM10_GD.FindFirstPartMtlSysRowID(String company, String partNum, String revisionNum, String altMethod, Int32 mtlSeq) in c:\_Releases\ERP\RL10.2.200.0\Source\Server\Internal\BM\EngWBLib\BMM10-GD.i.Queries.cs:line 327 at Erp.Internal.BM.BMM10_GD.CopyECOAttachments(String ipECOGroupID, String ipECOPartNum, String ipECORevisionNum, String ipECOAltMethod) in c:\_Releases\ERP\RL10.2.200.0\Source\Server\Internal\BM\EngWBLib\BMM10-GD.i.cs:line 4616 at Erp.Internal.BM.BMM10_GD.CheckInRev(ECORev aECORev) in c:\_Releases\ERP\RL10.2.200.0\Source\Server\Internal\BM\EngWBLib\BMM10-GD.i.cs:line 3098 at Erp.Internal.BM.BMM10_GD.CheckInAll(String ipGroupID, String ipAuditText, String& cResultsString) in c:\_Releases\ERP\RL10.2.200.0\Source\Server\Internal\BM\EngWBLib\BMM10-GD.i.cs:line 713 at Erp.Services.BO.EngWorkBenchSvc.CheckInAll(String ipGroupID, String ipPartNum, String ipRevisionNum, String ipAltMethod, Nullable
1 ipAsOfDate, Boolean ipCompleteTree, Boolean ipReturn, Boolean ipGetDatasetForTree, Boolean ipUseMethodForParts, Boolean ipValidPassword, String ipAuditText, String& opResultString) in C:_Releases\ERP\UD10.2.200.6\Source\Server\Services\BO\EngWorkBench\EngWorkBench.cs:line 8399
at Erp.Services.BO.EngWorkBenchSvcFacade.CheckInAll(String ipGroupID, String ipPartNum, String ipRevisionNum, String ipAltMethod, Nullable1 ipAsOfDate, Boolean ipCompleteTree, Boolean ipReturn, Boolean ipGetDatasetForTree, Boolean ipUseMethodForParts, Boolean ipValidPassword, String ipAuditText, String& opResultString) in C:\_Releases\ERP\UD10.2.200.6\Source\Server\Services\BO\EngWorkBench\EngWorkBenchSvcFacade.cs:line 2390 at SyncInvokeCheckInAll(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func
2 func) in C:_Releases\ICE\ICE3.2.200.6\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in C:_Releases\ICE\ICE3.2.200.6\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 47
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:_Releases\ICE\ICE3.2.200.6\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at Epicor.ServiceModel.Channels.ImplBase1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets) at Erp.Proxy.BO.EngWorkBenchImpl.CheckInAll(String ipGroupID, String ipPartNum, String ipRevisionNum, String ipAltMethod, Nullable
at Erp.Adapters.EngWorkBenchAdapter.CheckInAll(String ipGroupID, String ipPartNum, String ipRevisionNum, String ipAltMethod, DateTime ipAsOfDate, Boolean ipCompleteTree, Boolean ipReturn, Boolean ipGetDatasetForTree, Boolean ipUseMethodForParts, Boolean ipValidPassword, String ipAuditText, String& opResultString)
