I am wanting to adjust a few things in Sales Order Pick so it works better for us. I added in two new tables and everything so far seemed to be going well, until this.
.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: System.Web.Services.Protocols.SoapException: An error has occurred during report processing. ---> Microsoft.ReportingServices.ReportProcessing.ProcessingAbortedException: An error has occurred during report processing. ---> Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for dataset 'OrderHed'. ---> System.Data.SqlClient.SqlException: Incorrect syntax near 'T1'.
at Microsoft.ReportingServices.Library.ReportExecution2005Impl.InternalRender(String Format, String DeviceInfo, PageCountMode pageCountMode, Stream& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at Microsoft.ReportingServices.Library.ReportExecution2005Impl.Render(String Format, String DeviceInfo, PageCountMode pageCountMode, Byte[]& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at Microsoft.ReportingServices.WebServer.ReportExecutionService.Render(String Format, String DeviceInfo, Byte[]& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
Stack Trace:
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Ice.Core.SsrsReportService.ReportExecutionService.Render(String Format, String DeviceInfo, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds) in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\Web References\SsrsReportService\Reference.cs:line 633
at Ice.Core.SsrsReporting.SsrsRendererBase.Render(SsrsRenderInformationBase renderInformation) in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 142
at Ice.Core.SsrsReporting.SsrsRendererBase.<>c__DisplayClass12_0.<TraceReportRendered>b__0() in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 87
at Epicor.Hosting.Trace.TraceHandle.TimeAction(Action actionToTime) in C:\_Releases\ICE\ICE3.2.300.30\Source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 92
at Epicor.Hosting.Trace.TraceHandle.AddTimedIfEnabled(String traceFlag, Action actionToTime, Func`2 messageBuilder) in C:\_Releases\ICE\ICE3.2.300.30\Source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 39
at Ice.Core.SsrsReporting.SsrsRendererBase.TraceReportRendered(String printProgram, String ssrsRenderFormat, Func`1 timedAction) in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 95
at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReportForPreviewOrGenerate(RenderedSsrsReport renderedReport) in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 264
at Ice.Core.SsrsReporting.ReportProcessorBase.ProcessReportPart(String reportLocation) in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 158
at Ice.Core.SsrsReporting.StandardReportProcessor.ProcessReportParts() in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\SsrsReporting\StandardReportProcessor.cs:line 31
at Ice.Core.RoutingAndBreaking.ReportPersister.Persist(ReportInstanceInformation reportInstance, Func`2 reportsRenderer, Action`1 fillSysRptLstRow, Action`2 processReport, Func`3 filterTableAttachmentsFunc) in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ReportPersister.cs:line 57
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RenderUnroutedSsrsReport() in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 303
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RunSsrsReportIfEnabled() in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 228
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.ProcessReportWithDataInPlace(Func`2 executeCommand, Func`2 executeReader, SqlObjectsCreated sqlObjectsCreated) in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 111
at Ice.Core.RptBase.ReportDatabaseBuilder.XMLClose() in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 93
at Ice.Core.RptTaskBase`1.XMLClose() in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 216
at Ice.Core.TaskBase`1.StartProcess(Int64 instanceTaskNum, String outputFileName) in C:\_Releases\ICE\ICE3.2.300.30\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskBase.cs:line 47
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:\_Releases\ICE\ICE3.2.300.30\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 98
at Ice.Hosting.TaskCaller.ExecuteTask() in C:\_Releases\ICE\ICE3.2.300.30\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 57
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 577
