Error: 4GL STOP condition: The Server application has returned an er
I did my research on this error. I tried modifying the bpm logs and check the appserver logs for errors but nothing.
Epicor says it must be that we havent set up our logs to verbose and that we need to set up a debugalert !!
Did anyone happen to have a problem like this?
ANy help is appreciated,
Lissette Contreras
KEC
Corona,CA
Stack Trace
at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID, String procedureName, ParameterSet parms, Boolean persistent, Boolean internal_Renamed, Int64 procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String requestID, String fullProcedureName, ParameterSet inparams, Object procId, MetaSchema localSchema, Int32 stateModel)
at Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String requestID, String procedureName, ParameterSet parms, MetaSchema schema)
at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String procedureName, ParameterSet parms, MetaSchema schema)
at Epicor.Mfg.Proxy.ReqImpl.Update(ReqDataSet ds)
at Epicor.Mfg.UI.Adapters.ReqAdapter.Update()
at Epicor.Mfg.UI.App.ReqEntry.Transaction.Update()
