I have attached one of my procedure notes, it may benefit
Section 33 INVENTORY VALUES
STOCK WRITE DOWN
AVERAGE COSTS FOR INVENTORY
STOCK VALUES
PART COSTS
PART WRITE DOWN
We use average part costing. This is assigned in Part setup (Costing Method = Avg)
When “Writing stock off” ie assigning a $0.00 value to the stock or making the stock any other “prescribed “ $ amount, the Cost Method must be changed set to Std not Avg
STOCK WRITE DOWN PROCEDURE
- At >Part Setup select Costing Method = Std
- Then go to >Cost Adjustments and enter the new prescribed cost
- Then go to >Quantity Adjustments and change the stock quantities if necessary
Note Average Unit Cost is NOT the same as Unit Cost Generally average cost is used to calculate Inventory values ie total stock values and unit costs is used to calculate the cost of each separate transaction.
For example old stock has, say unit costs $A and qty Q1
And the same stock purchased after a price increase has a unit cost of $B and Q2.
The average costs will depend on the values and quantity of each lot and will not be equal to either $A or $B
Note. Mtl Unit Cost shown on reports is the current material unit cost and is equal to either
- The standard cost if the part is set up for STD costs
- Or the Average cost if the part is set up for AVG costs
- Or the Adjusted unit cost (when the cost method is set to AVG and the quantity of stock has not changed)
Note. If a part is setup for AVG costing the Mtl Unit Cost is updated/overwritten with a new Average
only when the Quantity on hand value changes
AVERAGE COST CALCULATION
The average cost is calculated when the Quantity on Hand value changes.
The value is calculated as
• New Average Cost = (Prev. Quantity x Prev.Unit Cost) + (Quantity Received x Receipt Unit Cost) / New Quantity On Hand
• Where Prev.Quantity" and “Prev.Unit Cost” are stored somewhere as opposed to being summed up for each transaction.
PROBLEMS CAUSED WHEN WRITING DOWN STOCK AND NOT CHANGING TO STD COSTS
The following example illustrates the problems that can occur when Average costs are overwritten.
In this example, stock was written off and cost was set to zero. However at stock take it was found the stock value was not at $zero.
The stock value did however automatically adjust to $zero after a sale of the stock as shown below.
(In this example the part should have been changed from AVG (average)to STD (standard) cost when the stock was written off and its unit value changed to $0.00. )
For part 300057
- The stock value used for stock take on 29/6/18 was $76.72/m Total stock value = $35,137.
- On the 13/9/2018 the stock was written off and value changed to $0.00/m Total stock value = $ 0.00
Referring to the following Epicor reports it is seen the
28/6/18 Stock status report for the material (pre stock take) shows the average unit costs as $76.72
30/6/18 Stock status report for the material (post stock take) shows the average unit costs as $76.72
2/7/18 Sale to Customer this changed the Stock Qty on Hand refer Part Transaction History
2/7/18 As a consequence of the Qty change the Average cost automatically recalculated as follows
New Average Cost = (Prev. Quantity (458m)x Prev.Unit Cost ($0.00)) + (Quantity Received
(-4.8m)x Receipt Unit Cost ($0.00)) / New Quantity On Hand (453.2m) .
>> new Average Cost = $0.00
2/7/18 The stock status report now shows the (new) average unit cost as $0.00
