Is there a way to prevent Epicor 10.2.100.9 from automatically trying to open Active Home page first before opening the standard modern UI? I uncommented the homepageurl in the client sysconfig file and Epicor still attempts to launch that UI first.
We have an app server serving SSO. How do we disable active home page for all clients connected to this app server? i can add the switch to the icon at the user level but how do i publish this change to everyone?
Go to your deployment folder on your server and modify the config file in the client folder for your SSO environment by commenting out the HomePageUrl attribute. It will no longer launch the active home page by default for sso.
i should note that if you already deployed the installation to clients then you need to modify all the configs at client level or redeploy.
Awesome! That worked. Epicor Support said it was not possible. You proved otherwise. Epicor support did submit this as an enhancement request to make a 3rd
option within launch type. It will be available sometime in 10.2.500+ (which I don’t think will be released in time for my upgrade for tomorrow) Thanks again!
