EpiUltraGrid Customization
Thanks, that's what i was looking for.
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> I added this code and the fields are truely read only. If you want
> the background grayed out you will have to set the background color
> of the grid...
> Dim dtCO as DataTable = dsCO.Tables(0)
> For Each dcCO as DataColumn in dtCO.Columns
> dcCO.ReadOnly = True
> Next
> '----ugdCO is the name of the UltraGrid---
> ugdEpiCustom1.DataSource = dtCO
> --- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@>
> wrote:
> > I created my grid using a dataset and i didn't declare any
> dataviews.
> > Here is the code i used to populate the grid:
> > dim recSelected as boolean
> > Dim whereClause as string ="ShortChar01 = 'J06108'"
> > Dim dsCO as DataSet =
> > Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup
> (oTrans,"UD06Adapter",recSelected,False,whereClause)
> > ugdCO.DataSource = dsCO
> > --- In vantage@yahoogroups.com, Robert Brown <robertb_versa@> wrote:
> > > Try:
> > > Sub InitializeCustomCode()
> > > '// Begin Custom Method Calls
> > > '// End Custom Method Calls
> > > SetExtendedProps()
> > > End Sub
> > > Then create that SetExtendedProps() sub (right out of the
> technical
> > users guide) and set it to make the table.columns in your ultrgrid
> to
> > be read-only = true.
> > > Private Sub SetExtendedProps()
> > > Dim edvJO As EpiDataView = CType(oTrans.EpiDataViews
> ("JobOper"),
> > EpiDataView)
> > > If edvJO.dataView.Table.Columns.Contains("OpComplete") Then
> > edvJO.dataView.Table.Columns("OpComplete").ExtendedProperties
> ("ReadOnly")
> > = True
> > > End If
> > > End Sub
> > > Substistute your particular table.columns you want to be read
> only.
> > > You can also enable and disable controls in this sub.
> > > Rob Brown
> > > --- On Wed, 6/4/08, laidig.systems <laidig.systems@> wrote:
> > > From: laidig.systems <laidig.systems@>
> > > Subject: [Vantage] EpiUltraGrid Customization
> > > To: vantage@yahoogroups.com
> > > Date: Wednesday, June 4, 2008, 3:50 PM
> > > I wrote a customization that retrieves a dataset and displays it
> in an
> > > UltraGrid. My only problem is that it looks like it is editable.
> > > Even though it really isn't changing the tables. I have been
> looking
> > > for a way to add code to make my UltraGrid ReadOnly. Does anyone
> know
> > > of a way to do this? I tried:
> > > UltraGrid1.ReadOnly = True
> > > but that produces an error when i run it. UltraGrid1.Enabled=
> False
> > > works somewhat but then the scrollbars don't work, and that isn't
> good
> > > either. Does anyone have any suggestions? Do i have to set the
> data
> > > readonly and not the Grid?
I wrote a customization that retrieves a dataset and displays it in an
Even though it really isn't changing the tables. I have been looking
for a way to add code to make my UltraGrid ReadOnly. Does anyone know
but that produces an error when i run it. UltraGrid1.Enabled=False
works somewhat but then the scrollbars don't work, and that isn't good
either. Does anyone have any suggestions? Do i have to set the data
You will probably have to set each column to be read only in the dataset
--- In vantage@yahoogroups.com, "laidig.systems" <laidig.systems@...>
Try:
SetExtendedProps()
End Sub
Then create that SetExtendedProps() sub (right out of the technical users guide) and set it to make the table.columns in your ultrgrid to be read-only = true.
Dim edvJO As EpiDataView = CType(oTrans.EpiDataViews("JobOper"), EpiDataView)
edvJO.dataView.Table.Columns("OpComplete").ExtendedProperties("ReadOnly") = True
End If
End Sub
Substistute your particular table.columns you want to be read only.
Rob Brown
but that produces an error when i run it. UltraGrid1.Enabled= False
I created my grid using a dataset and i didn't declare any dataviews.
Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,"UD06Adapter",recSelected,False,whereClause)
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...> wrote:
> Try:
> SetExtendedProps()
> End Sub
EpiDataView)
= True
> End If
> End Sub
> Rob Brown
> From: laidig.systems <laidig.systems@...>
of the grid...
Next
dataviews.
> > Try:
> > SetExtendedProps()
> > End Sub
technical
to
("JobOper"),
> EpiDataView)
("ReadOnly")
> = True
> > End If
> > End Sub
only.
> > Rob Brown
in an
looking
know
False
good
data
