EpiUltraGrid BAQDataView Upgrading from 10.2.400 to 2021.2.18
Let me start with, “I’m not really a programmer”.
I have BPMForm customization that I developed a long while back (with a bit of help from @josecgomez & @Banderson) that embeds BAQ data in an epiUltraGrid. This is working in our Production install of 10.2.400. However, during the upgrade process to 2021.2, all the custom codes got removed.
Looks like Epicor moved from private voids to private static voids; which I’m guessing is cause of the issue. I’ve managed to get some of it working (well not error in Test Code) but I’m still stuck with these 4 errors
 Error: CS0120 - line 95 (419) - An object reference is required for the non-static field, method, or property 'Script.baqViewMtlList'
 Error: CS0120 - line 96 (420) - An object reference is required for the non-static field, method, or property 'Script.baqViewMtlList'
 Error: CS0120 - line 120 (444) - An object reference is required for the non-static field, method, or property 'Script.baqViewMtlList'
 Error: CS0120 - line 121 (445) - An object reference is required for the non-static field, method, or property 'Script.baqViewMtlList'
Original Code
// Custom code for IP_MtlWarning
// Created: 6/21/2019 12:03:16 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Broadcast;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using System.Reflection;
using Infragistics.Win;
using Infragistics.Win.UltraWinGrid;
public class Script
	BAQDataView baqViewMtlList;
	EpiUltraGrid eugMtlGrid;
		this.btnLaunchMassIssue.Click += new System.EventHandler(this.btnLaunchMassIssue_Click);
		this.btnIssueMtl.Click += new System.EventHandler(this.btnIssueMtl_Click);
		CreateMtlListBAQView();
public void CreateMtlListBAQView()
	baqViewMtlList = new BAQDataView("OutstandingJobOpMtls");
	oTrans.Add("OutstandingJobOpMtls_BAQ",baqViewMtlList);
    EpiDataView edvBPMdata = (EpiDataView)(oTrans.EpiDataViews["BPMData"]);
    string sJobNum = Convert.ToString(edvBPMdata.dataView[edvBPMdata.Row]["Character01"]);
    int iAsmSeq = Convert.ToInt32(edvBPMdata.dataView[edvBPMdata.Row]["Number01"]);
	txtJobNum.Value = sJobNum;
	txtAsmSeq.Value = iAsmSeq;
	string char01Binding = "BPMData.Character01";
	string num01Binding = "BPMData.Number01";
	string num02Binding = "BPMData.Number02";
	IPublisher jobPub = oTrans.GetPublisher(char01Binding);
	IPublisher asmPub = oTrans.GetPublisher(num01Binding);
	if(jobPub==null)
		oTrans.PublishColumnChange(char01Binding, "JobNum");
		oTrans.PublishColumnChange(num01Binding, "AsmSeq");
	if(jobPub !=null)
		baqViewMtlList.SubscribeToPublisher(jobPub.PublishName, "JobMtl_JobNum");
		baqViewMtlList.SubscribeToPublisher(asmPub.PublishName, "JobMtl_AssemblySeq");
	jobPub.PublishInitialValue(sJobNum,true);
	var edv = (EpiDataView)(oTrans.EpiDataViews["CallContextBpmData"]);
	edv.dataView[edv.Row]["Character01"] = sJobNum;
		this.btnLaunchMassIssue.Click -= new System.EventHandler(this.btnLaunchMassIssue_Click);
		this.btnIssueMtl.Click -= new System.EventHandler(this.btnIssueMtl_Click);
		// Begin Custom Code Disposal
		// End Custom Code Disposal
	private void btnLaunchMassIssue_Click(object sender, System.EventArgs args)
		LaunchFormOptions lfo = new LaunchFormOptions();
		lfo.ValueIn = txtJobNum.Value;
		ProcessCaller.LaunchForm(this.oTrans, "IMGO3020",lfo);
	private void IP_MtlWarning_Load(object sender, EventArgs args)
		// Add Event Handler Code
	IP_MtlWarning.StartPosition = FormStartPosition.CenterScreen;
	System.Drawing.Rectangle wa = Screen.PrimaryScreen.WorkingArea;
	IP_MtlWarning.Location = new System.Drawing.Point((wa.Right - IP_MtlWarning.Width) / 2, (wa.Bottom - IP_MtlWarning.Height) / 2);
	private void btnIssueMtl_Click(object sender, System.EventArgs args)
		ProcessCaller.LaunchForm(this.oTrans, "IMGO3005", lfo);
New Code
// Created: 6/3/2022 4:01:06 PM
using System;
using System.Data;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
public class Script
	public static void InitializeCustomCode()
		Script.btnIssueMtl.Click += new System.EventHandler(Script.btnIssueMtl_Click);
		Script.btnLaunchMassIssue.Click += new System.EventHandler(Script.btnLaunchMassIssue_Click);
	public static void DestroyCustomCode()
		Script.btnIssueMtl.Click -= new System.EventHandler(Script.btnIssueMtl_Click);
		Script.btnLaunchMassIssue.Click -= new System.EventHandler(Script.btnLaunchMassIssue_Click);
	private static void IP_MtlWarning_Load(object sender, EventArgs args)
	private static void btnIssueMtl_Click(object sender, System.EventArgs args)
		ProcessCaller.LaunchForm(Script.oTrans, "IMGO3005", lfo);
	private static void btnLaunchMassIssue_Click(object sender, System.EventArgs args)
		ProcessCaller.LaunchForm(Script.oTrans, "IMGO3020",lfo);
public static void CreateMtlListBAQView()
	if(jobPub==null)
	if(jobPub !=null)
Any help, guidance, sample code, etc… would be gratefully appreciated.
Thank you,
oh look, it’s 5 pm on a Friday, time for a beer!
Okay, after a night of sleep I tackled this again. I believe I’ve corrected the syntax and it seems to be working correctly now.
"Corrected Code
// Created: 6/4/2022 1:00:11 PM
using System;
using System.Data;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
public static class Script
		Script.btnLaunchIssueMtl.Click += new System.EventHandler(Script.btnLaunchIssueMtl_Click);
	if(jobPub==null)
	if(jobPub !=null)
		Script.btnLaunchIssueMtl.Click -= new System.EventHandler(Script.btnLaunchIssueMtl_Click);
	private static void btnLaunchIssueMtl_Click(object sender, System.EventArgs args)
