EpiUltraCombo showing several columns
I guess I mis-understood.  I thought you wanted more than one column.  The UltraCombo is for multiple columns.  When I only want one, I tend to use the epiCombo.  Having said that…  In customization properties you should see “Col1ManualWidth” etc under “Misc”.  I set the ones I don’t want to show to 0.
Brenda
Sent: Thursday, May 15, 2014 12:35 PM
Subject: RE: [Vantage] EpiUltraCombo showing several columns
Thank you Brenda,
I'm not a code person, so looking at this, I'm not seeing any difference between what you have and what I have except you are displaying 2 fields.  I'm pasting my code:
private void SearchOnManufacturerAdapterFillDropDown()
                        // Wizard Generated Search Method
                        // You will need to call this method from another method in custom code
                        // For example, [Form]_Load or [Button]_Click
                        bool recSelected;
                        string whereClause = string.Empty;
                        System.Data.DataSet dsManufacturerAdapter = Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(this.oTrans, "ManufacturerAdapter", out recSelected, false, whereClause);
                        if (recSelected)
                                    // Set EpiUltraCombo Properties
                                    this.EUCManufacturer.ValueMember = "MfgID";
                                    this.EUCManufacturer.DataSource = dsManufacturerAdapter;
                                    this.EUCManufacturer.DisplayMember = "Name";
                                    string[] fields = new string[] {
                                                            "Name"};
                                    this.EUCManufacturer.SetColumnFilter(fields);
            private void EUCManufacturer_BeforeDropDown(object sender, System.ComponentModel.CancelEventArgs args)
                        SearchOnManufacturerAdapterFillDropDown();
I created an EpiUltraCombo to get the manufacturer name on the Job Details.  I created the code using the simple search wizard then the event wizard, and it works great, except for one thing, the drop down displays several columns, not just the manufacturer name.  What am I missing?
I added the columns in the code:  (this is E9.05.702 code).
                private void SearchOnPartAdapterFillDropDown()
                                bool recSelected;
                                System.Data.DataSet dsPartAdapter = Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(this.oTrans, "PartAdapter", out recSelected, false, whereClause);
                                if (recSelected)
                                                this.ucbPartNum.ValueMember = "PartNum";
                                                this.ucbPartNum.DataSource = dsPartAdapter;
                                                this.ucbPartNum.DisplayMember = "PartNum";
        "PartNum", "PartDescription"};
                                                this.ucbPartNum.SetColumnFilter(fields);
                private void RMAProcForm_Load(object sender, EventArgs args)
                                // Add Event Handler Code
                                SearchOnPartAdapterFillDropDown();
Brenda
E10.500.1
Sent: Wednesday, May 14, 2014 2:06 PM
Subject: [Vantage] EpiUltraCombo showing several columns
Thank you Brenda,
bool recSelected;
if (recSelected)
"Name"};
