EpiTimeEditor
Does anyone have custom code for the EpiTimeEditor that actually works? I’ve tried to match what they are doing in Time and Expense Entry. The Time tab has a Time editor which is bound to a field set as a double to store hours.decimal since midnight. I can’t seem to replicate this functionality.
I’m on version 10.1.600.30
Did you get to the bottom of this? If you assign the control to an integer, it seems to be seconds past midnight. There must be a hidden parameter to make it work like in the time and expense is what I’m thinking, but haven’t been able to find anything.
