EpiTimeEditor datatype issues
I am sure that the more experienced technical members here might have a bit of a smile at this one…
So for posterity…The EpiTimeEditor accepts a number as the value not a date time. In E9 time is stored in a number field as second from midnight. so I guess this is its origin… In order to get around this awkward circumstance I replaced the EpiTimeEditor with an EpiDateTimeEditor and use the following code in the form load to make the EpiDateTimeEditor look like the EpiTimeEditor.
		dtStartTime.DropDownButtonDisplayStyle = ButtonDisplayStyle.Never;
		dtStartTime.SpinButtonDisplayStyle = ButtonDisplayStyle.Always;
		dtStartTime.MaskInput = "hh:mm";
This allowed me use a DateTime field which was added as I notice that in the schema of the database for the UD table all the existing date fields were only a Date datatype.
So an absolutely HUGE Shout out to Hidayat from the CSG team in Malaysia who pointed me in the right direction.
I guess I won’t be using the EpiTimeEditor any time soon.
Here I am digging up old posts again…
The implementation of EpiTimeEditor is baffling me since it’s working in the time and expense screen how I expect it should. i.e. bind to a decimal value and it is hours.fractionofhour.
When adding the custom control, no matter the binding, the value used is always seconds past midnight EXCEPT for 00:00, which is storing a value of 24.
I guess I’ll have to try the EpiDateTimeEditor, but it really seems like I shouldn’t have to. Is there possibly a hidden parameter to make EpiTimeEditor behave like in the time and expense form?
I take back the bit about the 00:00 being stored as 24…unsurprisingly, I had not removed one of my tests and it was setting the 24. Still, there must be some way to make the control behave as per the time editor.
For those following along, it turns out very simple. Add the following to the InitializeCustomCode():
YourControl.EpiDecimal = true;
Another useful one, so that 12am doesn’t disappear, is:
YourControl.EpiTreatZeroAsNull= false;
Saved my bacon today @Hally . :beers:
