When I click the drop down I get a server error, which I can’t view as I am a SaaS cloud user. (I tried using the download tool, but I can’t find any log)
If I remove the filter the error goes away. I tried doing a trace:
And it worked fine. So I think there must be something wrong with my control properties. I tried deleting it and starting over, which did not fix the problem.
Is there any way I can get my hands on the server log? Or is there anything wrong with the combo properties?
< miniRant >
I had the same issue with the BPM recently. Logging items to the Windows Event log is just a bad idea™. First, you have to give devs access to the server - which is a Really Bad Idea™ but in SaaS situations, you would have to file a ticket with your cloud team, tell them about when the error happened so THEY can look at the event log. Grrr.
< /miniRant >
I agree, I would think it would be fairly high on the list of things to improve for cloud users. If they have the logging abstracted to a logging service I would think it would be relatively easy to fix too…
Can I filter by the UD field character01? I just need to display a different sub-group of UD codes depending on what customer group the customer is in.
Trying to use this same method for a dashboard. The drop down choices for Sales Categories should be filtered such that only UD codes with Character01 = Group are displayed in the drop down.
