I probably should know this but don’t. When in customization mode, one can go to Tools and then Object Explorer. That’s where all of the data adapters are but there is a tab called Data Objects. This is where the EpiDataViews are found. My question is, where are these EpiDataViews housed? How are they defined? I am trying to track down an issue where erroneous data is getting populated in SQL table and the textbox its coming from has an EpiBinding to an EpiDataView. So, I need to understand this a little more and if any of you guys have any insight, I would appreciate it.
EpiDataViews are local objects that give you a “view” to datatables. They are basically local representations of the database tables but will include calculated or combined values not always directly correlating to the database. They are in memory not really “stored” anywhere
Thank you for this insight.
