Hi,
I’m trying to add 5 customized fields to QuoteHed and bind to EpiCurrencyConver control.
I created 5 UD fields for each 1 customized field because 5 fields are needed to one EpiCurrencyConver.
Example: Equipment1_c, DocEQuipment1_c, Rpt1Equipment1_c, Rpt2Equipment1_c, Rpt3Equipment_3.
I also want to do a simple math calculation DocTargetPriceTotal=DocEquipment1 + DocEquipment2 + DocEquipment3 + DocEquipment4.
I tried to use EpiViewNotificaon and AfterFieldChange, however, it does not turn out the results I wanted.
Here’s my codes in Script Editor, could any guide me?
Summary
// Custom code for QuoteForm
// Created:
extern alias Erp_Contracts_BO_QuoteDtlSearch;
extern alias Erp_Contracts_BO_Quote;
extern alias Erp_Contracts_BO_Customer;
extern alias Erp_Contracts_BO_AlternatePart;
extern alias Erp_Contracts_BO_Part;
extern alias Erp_Contracts_BO_Vendor;
extern alias Erp_Contracts_BO_VendorPPSearch;
extern alias Erp_Contracts_BO_ShipTo;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Ice.BO;
public class Script
// ** Wizard Insert Location - Do Not Remove ‘Begin/End Wizard Added Module Level Variables’ Comments! **
private EpiDataView edvQuoteHed;
private EpiCurrencyConver DocEquipment1;
private EpiCurrencyConver DocEquipment2;
private EpiCurrencyConver DocEquipment3;
private EpiCurrencyConver DocEquipment4;
private EpiCurrencyConver DocTargetPriceTotal;
this.DocEquipment1=(EpiCurrencyConver)csm.GetNativeControlReference("09db2557-a67f-427e-b261-7e75aa86bcb2");
this.DocEquipment2=(EpiCurrencyConver)csm.GetNativeControlReference("7339e514-5aad-4371-95ff-8a1ec15f8906");
this.DocEquipment3=(EpiCurrencyConver)csm.GetNativeControlReference("119a0283-0c90-4d32-8b5d-e3d4262da649");
this.DocEquipment1=(EpiCurrencyConver)csm.GetNativeControlReference("db4028a0-9fcc-44f4-9044-e890f677bcee");
this.DocTargetPriceTotal=(EpiCurrencyConver)csm.GetNativeControlReference("76e54963-335f-424a-a19f-56dc34b4c949");
DocEquipment1.EpiBindingDocument="QuoteHed.Doc Equipment1_c";
DocEquipment2.EpiBindingDocument="QuoteHed.Doc Equipment2_c ";
DocEquipment3.EpiBindingDocument="QuoteHed.Doc Equipment3_c ";
DocEquipment4.EpiBindingDocument=" QuoteHed.Doc Equipment4_c ";
DocTargetPriceTotal.EpiBindingDocument="QuoteHed.DocTargetPriceTotal_c";
this.edvQuoteHed = ((EpiDataView)(this.oTrans.EpiDataViews["QuoteHed"]));
this.edvQuoteHed.EpiViewNotification += new EpiViewNotification(this.edvQuoteHed_EpiViewNotification);
this.QuoteHed_Column.ColumnChanged += new DataColumnChangeEventHandler(this.QuoteHed_AfterFieldChange);
this.edvQuoteHed.EpiViewNotification -= new EpiViewNotification(this.edvQuoteHed_EpiViewNotification);
this.edvQuoteHed = null;
this.QuoteHed_Column.ColumnChanged -= new DataColumnChangeEventHandler(this.QuoteHed_AfterFieldChange);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void edvQuoteHed_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
// view.dataView[args.Row]["FieldName"]
// args.Row, args.Column, args.Sender, args.NotifyType
// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
if ((args.NotifyType == EpiTransaction.NotifyType.AddRow))
if ((args.Row > -1))
EpiDataView edvQuoteHed=(EpiDataView)oTrans.EpiDataViews[“QuoteHed”];
edvQuoteHed.dataView[edvQuoteHed.Row].BeginEdit();
decimal DocEuipment1=Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row][" DocEuipment1_c"]);
decimal DocEuipment2=Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row][" DocEuipment2_c"]);
decimal DocEuipment3=Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row][" DocEuipment3_c"]);
decimal DocEuipment4=Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row][" DocEuipment4_c"]);
decimal DocTargetPriceTotal= DocEuipment1+ DocEuipment2+ DocEuipment3+ DocEuipment4;
edvQuoteHed.dataView[edvQuoteHed.Row]["DocTargetPriceTotal_c"]=DocTargetPriceTotal;
edvQuoteHed.dataView[edvQuoteHed.Row][" Euipment1_c"]=Math.Truncate(DocEuipment1*Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["ExchangeRate"]));
edvQuoteHed.dataView[edvQuoteHed.Row][" Euipment2_c "]=Math.Truncate(DocEuipment2*Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["ExchangeRate"]));
edvQuoteHed.dataView[edvQuoteHed.Row][" Euipment3_c"]=Math.Truncate(DocEuipment3*Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["ExchangeRate"]));
edvQuoteHed.dataView[edvQuoteHed.Row][" Euipment4_c"]=Math.Truncate(DocEuipment4*Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["ExchangeRate"]));
edvQuoteHed.dataView[edvQuoteHed.Row]["DocTargetPriceTotal_c"]=Math.Truncate(DocTargetPriceTotal*Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["ExchangeRate"]));
edvQuoteHed.dataView[edvQuoteHed.Row].EndEdit();
private void QuoteHed_AfterFieldChange(object sender, DataColumnChangeEventArgs args)
// args.Row["FieldName"]
// args.Column, args.ProposedValue, args.Row
// Add Event Handler Code
EpiDataView edvQuoteHed=(EpiDataView)oTrans.EpiDataViews["QuoteHed"];
decimal DocVendorAncillaries=Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["DocVendorAncillaries_c"]);
decimal DocValueAddedAncillaries=Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["DocValueAddedAncillaries_c"]);
decimal DocSolexAncillaries=Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["DocSolexAncillaries_c"]);
decimal DocHeatExchanger=Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["DocHeatExchanger_c"]);
decimal DocTargetPriceTotal=DocVendorAncillaries+DocValueAddedAncillaries+DocSolexAncillaries+DocHeatExchanger;
switch (args.Column.ColumnName)
case "DocTargetPriceTotal_c":
decimal DocEquipment1=Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row][" DocEquipment1_c"]);
decimal DocEquipment2=Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row][" DocEquipment2_c"]);
decimal DocEquipment3=Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row][" DocEquipment3_c"]);
decimal DocEquipment4=Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row][" DocEquipment4_c"]);
decimal DocTargetPriceTotal= DocEquipment1+ DocEquipment2+ DocEquipment3+ DocEquipment4;
edvQuoteHed.dataView[edvQuoteHed.Row]["Equipment1_c"]=Math.Truncate(DocEquipment1*Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["ExchangeRate"]));
edvQuoteHed.dataView[edvQuoteHed.Row][" Equipment2_c"]=Math.Truncate(DocEquipment2*Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["ExchangeRate"]));
edvQuoteHed.dataView[edvQuoteHed.Row][" Equipment3_c"]=Math.Truncate(DocEquipment3*Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["ExchangeRate"]));
edvQuoteHed.dataView[edvQuoteHed.Row][" Equipment4_c"]=Math.Truncate(DocEquipment4*Convert.ToDecimal(edvQuoteHed.dataView[edvQuoteHed.Row]["ExchangeRate"]));
break;
