Kathy Hambleton
VP of Finance
Electron Energy Corporation
Something that’s a blanket issue like that I would check the company config for. Make sure that in Company Config > Plant Configuration Control you hit up the Module tab and the Plant Warehouse Defaults tab for sure. Make sure those are all filled in as desired
Joshua Giese
CIO
920.437.6400 Ext. 337
Site ID: 27450-E905700B2-SQL64
Wisconsin Converting, Inc.
On Behalf Of Comcast
Sent: Tuesday, February 11, 2014 7:31 PM
To: Vantage Onelist
Subject: [Vantage] Epicor9 Receiving
In testing Epicor 9.05.702 we have a PO for other(Pur-Ukn type). When we create a receipt it requires us to choose a warehouse. Am I missing some setting? I don't want pens and pencils in inventory!
Kathy Hambleton
VP of Finance
Ensure that Quantity Bearing is not ticked at Part Maintenance
Sue
We ran into a similar issue while we were going through testing 9.05.702A. It appeared (at initial test) that the buyer must be in the "plant" that the "other" item was being Purchased for. We were testing multi-plant vs. single plant. It appeared that qty. bearing (inventory) items could be purchased and directed to which ever plant / warehouse needed regardless of which "plant" the buyer is logged into. However on MRO (other) purchases, the buyer had to be logged into the "plant" needing the MRO item. If the buyer was not in the correct "plant" we received the "warehouse needed message" that you were indicating.
Hope this helps! We will be revisiting / revalidating as we continue our testing.
Ron Brown
Tank Connection
620-423-3010
Ron Brown
Process Manager
Tank Connection
3609 N. 16th St.
Parsons, KS 67357
Office: 620-423-3010 ext. 158
Email: rbrown@...<mailto:rbrown@...>
[cid:tcaffiliates_200803b84f]<http://www.tankconnection.com>
[cid:linkedine39539] <http://www.linkedin.com/company/tank-connection-affiliate-group> [cid:facebookd68861] <http://facebook.com/tankconnection> [cid:twitter44bcfa] <http://twitter.com/TankConnection> [cid:youtube79af3e] <http://youtube.com/user/TankConnection>
NOTICE: This email and any attachments are considered confidential and intended for the addressee only. If you have received this email in error, please notify the sender as soon as possible and delete this email. If you are not the intended addressee, any dissemination, distribution or copying of this message is strictly prohibited by law.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Comcast
To: Vantage Onelist
Kathy Hambleton
VP of Finance
----- Original Message -----
Sent: Wed, 12 Feb 2014 14:36:56 -0000 (UTC)
Subject: [Vantage] RE: Epicor9 ReceivingThere is a bug where the warehouses from the purchase order aren't coming in for PUR-UKN PO lines when doing a mass receipt. We are on 9.05.701, I'm guessing it's in your version also as it has an open SCR. It's been assigned SCR 110938 without a target date. Maybe if enough people tack onto the SCR it will be addressed (wishful thinking I know!). I had some unhappy users that had to pick a warehouse for each line of large supply purchase orders. I ended up setting up a BPM that is triggered by the Set All to Locations button on the Mass Receipts form that brings in the default warehouses to the PUR-UKN lines.
Sue
Hello Kathy, I fixed this issue with a customization in the Mass Receipt:
I could show you my code if you need it.
Sent: Fri, 14 Feb 2014 15:18:34 -0000 (UTC)
Subject: [Vantage] RE: Epicor9 ReceivingHello Kathy, I fixed this issue with a customization in the Mass Receipt:
Hello Kathy good afternoon; my code does have errors when the PO Type is Other.
What I am trying to do now is once I know the PONum, I will go direct to the RcvDtl SQL table and update the WareHouseCode. Once I complete and test this I will post the code if you still need it.
Sent: Mon, 17 Feb 2014 19:55:52 -0000 (UTC)
Subject: [Vantage] RE: Epicor9 ReceivingHello Kathy good afternoon; my code does have errors when the PO Type is Other.
