I searched on the forums but could not find an answer.
We are standardising on using SharePoint online for company wide document management. We have activated document storage and can use it from the desktop client but we are getting a strange message adding attachments through Epicor Web Access to sharepoint. “CreateDocumentFolderFailed 403: forbidden” which suggests an authentication/authorisation problem.
More detail on our setup: Using SharePoint online with File transfer Using Service using a service account that is an owner of the site. Instance Epicor 10.2.200.14 if that is relevant. Our support provider has not come across this error before. We can use file folder storage from EWA and the client so attachments do work in general from EWA and uploads from the client work to sharepoint so it’s not an authentication problem with the service account.
EWA appears to fail to authenticate correctly using sharepoint online
We never had luck with the file transfer service. We use Client security and that works. Our SharePoint Admin has to create the folder for us. He logged into Epicor and clicked the Create folder button and it worked for him even though I was admin for the site the document library is in.
Same should be with file transfer. You specify credentials for user who can create folders and document types. Then create company folder and document types using that credentials.
Thanks - it works through the desktop client fine so the account having permission should not be the issue - I’ll trial with user credentials but I really don’t want users to have access to upload files directly to that site/library.
I didn’t mention we don’t use the public cloud service but host on our own servers. Thanks for the input so far - I’m going to spend some time seeing if the sharepoint logs can point to and issue (lost credentials etc) and trial using user credential
