Epicor Theme Maintenance
Hi,
I am using Epicor 10 and wonder if there is a bug in the Epicor Theme Maintenance.
I am able to customize the styling and import the style and icon, check on distributable, save the theme and select the theme in the preference for loading upon login. No issue for this
I supposed the “Distributable” check is meant to upload the style and theme to the server.
However if I edited the style and import in the existing theme and check on distributable, It’s still loading the old theme upon login. Tested to load the style from local drive confirm the change is made and no issue.
It seem to me that the distributable does not take effective for modification of existing theme.
It only work if I create a totally new theme name to import the edited style where the distributable will upload to server.
Appreciate if anyone can advice.
