Hi Experts,
I am configuring SSRS with Epicor 10.2 getting error while importing reports - Unable to find the Browser SSRS role. Please ensure that the Browser role has not been modified.
Surendra Pal
Hi Experts,
Surendra Pal
This sounds like a permissions rule. Browser is a role that can be added to someone that needs to looks at reports. If you go to your reports server, click the down arrow next to the folder you are trying to open the report in, then click on security. You should see all of the assigned roles. Chances are that something isnāt set right in there.
SSRS version?
Report server 2017. It is working fine with 2016
Regards,
Surendra Pal
Did you ever figure this out? I am having issues with this error on 10.2.100.5 and SSRS 2017. Also get this error.
Application Server Setup Failed.
Errors:
System.Web.Services.Protocols.SoapException: System.Web.Services.Protocols.SoapException: The item ā/Epicor10/reports/SharedReportDataSourceā cannot be found. ā> Microsoft.ReportingServices.Diagnostics.Utilities.ItemNotFoundException: The item ā/Epicor10/reports/SharedReportDataSourceā cannot be found.
at Microsoft.ReportingServices.Library.ReportingService2005Impl.SetItemDataSources(String Item, DataSource[] DataSources, Guid batchId)
at Microsoft.ReportingServices.Library.ReportingService2005Impl.SetItemDataSources(String Item, DataSource[] DataSources)
at Microsoft.ReportingServices.WebServer.ReportingService2010.SetItemDataSources(String ItemPath, DataSource[] DataSources)
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Ice.Lib.Reporting.SsrsReportingServiceCaller.<>c__DisplayClass5_0.b__0(IReportingService service)
at Ice.Lib.Reporting.SsrsReportingServiceCaller.DoWithService[TReturn](Func`2 action)
at Ice.Lib.Reporting.SsrsReportImporter.UpdateSharedDataSourcesInSsrsSite(SsrsReportDefinition report, String reportPath)
at Ice.Lib.Reporting.SsrsReportImporter.ImportReport(String reportPath, XDocument reportDocument)
at SetupEnvironment.Steps.ImportSsrsReports.ImportReportsInZipFile(SsrsReportImporter reportImporter, SsrsFolder ssrsFolder, String reportsBasePath, String reportZipPath)
at SetupEnvironment.Steps.ImportSsrsReports.ImportReportsInZipFiles(SsrsReportingServiceCaller serviceCaller, String reportsBasePath, String reportZipPaths)
at SetupEnvironment.StepBase.Run()
Epicor support saying SSRS 2017 not tested yet.
It looks to me like the Shared Data Source cannot be found. Try manually updating the Data Source on one of the smaller reports.
DaveO
Same issue, our client is using Server Reporting 2017, any solutions?
This is the latest info I have gotten from a support ticket about this. I have not found a working solution yet, will update if I do.
I also have the same issue with E10.2.100.6 on SQL 2017. In SSMS I connected to Reporting Services then Under Security | Roles | Browser - grant āView data sourcesā. However, this didnāt resolve the issue
This did resolve the issue for me. I am installing 10.2.100.8.
EDIT: seems i spoke too soon. Only one report was installed on the server so i ran the deployment again and the error returnedā¦
Brett
Does not appear to be fixed yet in 10.2.100.11 either.
Still gives āunable to find browser SSRS roleā in 10.2.100.11.
The first ERP release that will be certified for use with SQL 2017 is the upcoming 10.2.200 release.
pretty sure sql or ssrs 2017 isnāt supported on 10.2.100.x.
