Epicor Social and Enterprise Search - 10.0.700.4
Hi Stephen,
I am trying to get notifications of record changes.  (We have a standard licence – not sure how that limits the options – I know we cannot edit or add notification rules.)
I have selected to receive notification of new customers added and new lines added to a sales order.  The Enterprise Search index is rebuilt each hour.  I do not receive any notification even after the Enterprise Search can find the change.
If I go to the Notification Center and try to search for a Data Record, the message is:  “Error.  We are unable to process the request.  Please try again. (500) Unable to connect to Notification Source GibsonSocial’s ES search service.”
However if I search there for a Notification Profile it works OK.
(Is Epicor Web Access required?  We do not have that installed.)
Any suggestions appreciated…
-      Neil
Sent: Wednesday, 22 July 2015 9:07 AM
Subject: [Vantage] RE: Epicor Social and Enterprise Search - 10.0.700.4
What issue are you having Neil?
The setting should be as per the URL in company.
Sent: Tuesday, July 21, 2015 11:14 PM
Subject: [Vantage] Epicor Social and Enterprise Search - 10.0.700.4
Anyone out there using Epicor Social?
I am setting up Epicor Social and have it partly working.  The issue is the Enterprise Search URL for the Index that ESE will use.
Enterprise Search is working OK in the application.  Should I use the same URL as is in Company Maintenance or does ESE require its own index.  If so, is there a template for it?  What goes in it?
The URL in Company is http://MYSERVER:8098/search/ERP10TEST
Any guidance would be appreciated...
 - Neil
Notice:This e-mail and any attachments are confidential and are only for the use of the person to whom they are addressed. If you are not the intended recipient please advise the sender by return e-mail and delete the message and any attachments. Any use, interference with, disclosure or copying of this message or any attachments is unauthorised and prohibited. The sender does not warrant that the information is free of a virus or any other defect or error, and any views expressed herein, unless specifically indicated otherwise, are those of the individual sender.
The DH Gibson Group of Companies - http://www.gibsonshopfitters.com.au
P Please consider our shared environment before printing this communication.
Stephen Edginton (Beng) | Solutions & Technical Director
Mobile:
 +44 7734 858415
DDI:
 +44 121 314 1179
Main:
 +44 (0) 121 314 1170
Web:
 www.dotnetit.co.uk
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
DotNetIT
Epicor Platinum Partner
Epicor Alliance Partner
 - Neil
 - Neil
#ygrps-yiv-1498475819 P.ygrps-yiv-1498475819b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1498475819 LI.ygrps-yiv-1498475819b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1498475819 DIV.ygrps-yiv-1498475819b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1498475819 TABLE.ygrps-yiv-1498475819b1e7fd89-0279-4ffe-a16a-1f1bcba0d537Table { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1498475819 DIV.ygrps-yiv-1498475819Section1 { }
 - Neil
Mobile:  +44 7734 858415
DDI:  +44 121 314 1179
Main:  +44 (0) 121 314 1170
Web:  www.dotnetit.co.uk
DotNetIT
