Hi Team,
Anyone know to rectify the below issue.
Turn to classic mode also give the same results and reinstall Epicor also doesn’t work.
Epicor version: 10.2.600
Hi Team,
If that is just one user, try purging personalizations.
Hi, Done purge personalization. Still the same. Any other workaround?
if you run on the server with the /SHELL or the /KINETIC switch in the shortcut?
I had this happen when Indid something like save a layout or a theme or something.
