Epicor SaaS - Is there an easy way to lengthen the Order Number
Hard to believe that the Order Number is only 6 digits long. I need to make it at least 8 digits because we used “specific” number ranges for “specific” groups. :roll_eyes: :roll_eyes: :roll_eyes:
We are not going to be doing that in Kinetic, so I have to go to 7 digits to avoid duplicate SO numbers. Any easy way?
Have you checked company config or maint
In my dev 2323.2.8 this looks to be possible out of the box and without a schema changed needed,
In Extended property maint XaSyst holds the StartOrderNum
I updated just the Format field nothing else and saved.
In Company Configuration I set a new starting. The old was 800000
I made a new order and got this below. Added lines. make direct releases and ran the ojw and it all seemed fine.
Are you on prem or SaaS?
It won’t matter.
Just found out that it is a datafix from support. I am requesting it.
