Epicor Report Filter by
I have an “Epicor Report” (i.e. not a BAQ Report) and i added a Filter Criterial in the RDD. However, the filter does not appear to do anything.
If i look in the RptParameters UserCriterial i can see it in the XML - however it looks like the VB code is hard coded to look for rptCriteriaPrompt and my filter value is under rptCriterialFilter.
Any suggestions on how to exract the filter so I can apply it to either a dataset or to a Tablix?
DaveO
You will have to filter in the actual report (Crystal or SSRS).
