Epicor Mobile Warehouse Replenishment
We are currently trying to roll out Epicor Mobile Warehouse and I’m looking for how to do bin replenishment on the handheld. Currently my warehouse supervisor is doing a Stock Move and not an actual replenishment, but I have not been able to find out how or where to go to do Replenishment. Any direction would be greatly appreciated.
Hey Jeff,
you have to make a material queue query, then from there you can select it in your material queue to show just that one option.
if you go to setting -> Mtl Query
Click on new query and give it a name
then click into your new query and add a new filter.
In the column feild change the option to Trans Type and in the value box put RAU-STK this will show everything that has been automatically generated by your system, or if you want to show manual replenishments you can use RMN-STK
I hope this helps
