Hi,
Currently, I am learning Epicor Functions. I like the idea behind it and would like to use it when the opportunity presents itself. After testing the basics with the diagram editor I noticed the Part does not Update.
I tried the following flow with the process/blocks provided - and also tried the same approach via custom code only (which I will paste below)
The process is:-
Input:
PartNum
Output:
PartDescriptionOut
Variables:
tempPartTableset
Process:
- Invoke BO Method: GetByID
- Using input parameter PartNum
- data returned stored in tempPartTableset
- Set Field: PartDescription in tempPartTableset to some fixed value.
- Invoke BO Method: Update using tempPartTableset
- Set Argument/Variable: PartDescription to tempPartTableset.Part[0].PartDescription.
When I test this (using RestAPI) the PartDescriptionOut is the value I set it to. As the Update method should represetns the parameter (in this case tempPartTableset) as In/Out - then whatever was saved it what should be returned. However, when I refresh the epicor client, the part description has not changed.
I also did another GetByID after the Update (as expected) it did not Save/Update the changes.
I am trying to understand what I am doing wrong.
I also adjusted the function to just run custom code, which I have provided below… and it still does not Save/Update the changes:-
this.CallService<Erp.Contracts.PartSvcContract>(partService => {
try
tempPartTableset = partService.GetByID(“10005385”);
tempPartTableset.Part[0].PartDescription = "MS Change!";
partService.Update(ref tempPartTableset);
PartDescriptionOut = tempPartTableset.Part[0].PartDescription;
tempPartTableset = partService.GetByID("10005385");
PartDescriptionOut += " -- " + tempPartTableset.Part[0].PartDescription;
catch(Exception ex) {
PartDescriptionOut = ex.Message;
I am not sure why it does not update. The credentials I am using with the RestAPI is mine… and i am an admin user, etc. I tried running this epicor function in Staging and Live.
As for resources… I found this page helpful. I could not find anything on EPICWeb. I will admit that I could be searching incorrectly.
Once I get over this (basic) hurdle then I can start to do some advanced and useful things with it.
Any advice/suggestion is welcome. We are on 10.2.500.35
Thank you,
M
