When attempting to ‘print,’ ‘print preview’ or ‘generate only’ for any report, the message ‘report submitted…’ appears at the bottom of the window and nothing happens. A report job never makes it to the print queue (we verified that the printer is working correctly). When we look in System Monitor, we see the following error. We think we’ve granted the proper permissions on the applicable database, we’ve verified database health, we verified the schema ‘dbo’ exists, and we checked the Epicor logging within Windows Event Viewer. At this point, we are not sure what configuration to check in the Epicor application server settings or the DB configuration.
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: The specified schema name “dbo” either does not exist or you do not have permission to use it.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource
1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
at Ice.Core.RptBase.SqlTableBuilder.BuildTable(SqlConnection connection, String tableName, IEnumerable1 columns, SqlObjectsCreated sqlObjectsCreated) at Ice.Core.RptBase.SqlTableBuilder.BuildTable(SqlObjectsCreated sqlObjectsCreated) at Ice.Core.RptBase.ReportDatabaseBuilder
1.BuildSchemaAndWriteData(SqlConnection connection, SqlObjectsCreated sqlObjectsCreated)
at Ice.Core.RptBase.ReportDatabaseBuilder1.GenerateSqlObjectsProcessReportAndRemoveSqlObjects(SqlConnection connection) at Ice.Core.RptBase.ReportDatabaseBuilder
1.XMLClose()
at Erp.Internal.GL.GlBook.RunProcess(Int32 instanceTaskNum, String outputFileName)
at Ice.Hosting.TaskCaller.ExecuteTask()
at Ice.Services.Lib.RunTaskSvc.RunTask(Int32 ipTaskNum)
