What actual datatype is DATE expecting in Epicor? I am in C# and cant seem to satisfy it.
I’ve tried giving it a DateTime, DateTime?, and String.
It never complains, it just never uses my date either.
Wondering if you are working in a form customization, BPM? Which Table.Field(s)?
If you check the data dictionary… you’ll see some fields might be DateTime while others are Date.
For now, here are a few generic dates used in a form customization
// Get proposed due date
DateTime yourDate = DateTime.Parse(sArgs);
// Calc proposed days allowed
DateTime dToday = DateTime.Today;
var difference = yourDate - dToday;
// Store as an difference as an Integer
int iDays = difference.Days;
// convert
DateTime dateVal = Convert.ToDateTime(str);
// and this is part of an example is from the E10 Customization Guide
dtNeedByDate = Convert.ToDateTime(args.ProposedValue);
if (dtNeedByDate > System.DateTime.Today.AddDays(365))
MessageBox.Show(“Need By Date exceeds one year. Enter a valid Need By Date.”);
Thanks for the response Bruce. I am actually connecting from outside of Epicor. I am using the UD38Adapter.
Here is some relevant code (where my date isnt working proper):
See a.UD38Data.Tables[0].Rows[0][GetField(“Date1”)] = DateTime.Now;
UD38Adapter a = new UD38Adapter(oTrans);
a.ClearData();
string[] udparams = { pn,bin,lot, "" ,""};
try
got = a.GetByID(udparams);
catch { }
if (got) //found a record - do some shifting
decimal? count1 = (decimal)a.UD38Data.Tables[0].Rows[0][GetField("Count1")];
decimal? count2 = (decimal)a.UD38Data.Tables[0].Rows[0][GetField("Count2")];
decimal? count3 = (decimal)a.UD38Data.Tables[0].Rows[0][GetField("Count3")];
DateTime? date1 = null;
DateTime? date2 =null;
DateTime? date3 = null;
try
date1 = (DateTime?)a.UD38Data.Tables[0].Rows[0][GetField("Date1")];
date2 = (DateTime?)a.UD38Data.Tables[0].Rows[0][GetField("Date2")];
date3 = (DateTime?)a.UD38Data.Tables[0].Rows[0][GetField("Date3")];
catch { }
string user1 = a.UD38Data.Tables[0].Rows[0][GetField("User1")].ToString();
string user2 = a.UD38Data.Tables[0].Rows[0][GetField("User2")].ToString();
string user3 = a.UD38Data.Tables[0].Rows[0][GetField("User3")].ToString();
//now do shifts as needed - we know we have count1 cuz we got record
count3 = count2;
count2 = count1;
date3 = date2;
date2 = date1;
user3 = user2;
user2 = user1;
//last put the current & shitfted data
a.UD38Data.Tables[0].Rows[0][GetField("Count1")] = count;
a.UD38Data.Tables[0].Rows[0][GetField("Count2")] = count2;
a.UD38Data.Tables[0].Rows[0][GetField("Count3")] = count3;
a.UD38Data.Tables[0].Rows[0][GetField("Date1")] = DateTime.Now;
if(date2 != null) a.UD38Data.Tables[0].Rows[0][GetField("Date2")] = date2;
if(date3 != null) a.UD38Data.Tables[0].Rows[0][GetField("Date3")] = date3;
a.UD38Data.Tables[0].Rows[0][GetField("User1")] = currentUser;
a.UD38Data.Tables[0].Rows[0][GetField("User2")] = user2;
a.UD38Data.Tables[0].Rows[0][GetField("User3")] = user3;
a.Update();
else //not found, create
baseCreateRecord(pn, bin, lot, count);
a.ClearData();
What is Date3? I assume you meant Date03 or did you create custom field? If custom, can you paste a screenshot of custom field properties?
I cheat with my field names by using a custom method to translate to a friendly name:
public static string GetField(string field)
string res = "";
if (!FieldMap.TryGetValue(field, out res)) throw new Exception("Check your field map sucker!");
return res;
private void init_field_map()
FieldMap.Clear();
FieldMap.Add("Part", "Key1");
FieldMap.Add("Bin", "Key2");
FieldMap.Add("Lot", "Key3");
FieldMap.Add("Count1", "Number01");
FieldMap.Add("Count2", "Number02");
FieldMap.Add("Count3", "Number03");
FieldMap.Add("Date1", "Date01");
FieldMap.Add("Date2", "Date02");
FieldMap.Add("Date3", "Date03");
FieldMap.Add("User1", "Character01");
FieldMap.Add("User2", "Character02");
FieldMap.Add("User3", "Character03");
Essentially I am making a custom solution to perform a full inventory. It will allow parts to be counted up to 3 times (hence the user\date\count 1-3). Any part bin overages are moved to LOST bin. Do the actual qty adjustment on the overall part (against the LOST bin) - and log as needed. Then only part bin deficits exist - reconcile them from LOST. Should be left with 0 in LOST and count and actual values should match
I think I’ve figured out my date confusion - I assume because of the time zone settings of the server being one hour ahead of me - I kept logging the day before at 11pm instead of today at 12am.
That’s kind of funky but at least I understand what is happening. I would be much better suited to store the time than the date anyway since this all happens in the span of one day.
After reading this, I have to say that it’s really nice to see @bordway and @danbedwards help @Chris_Conn get a date…
@Chris_Conn why don’t you just make the fields with the right name to being with? Why bother using those fields at all? Except Keys(1-5) you don’t need to use any of those fields. You can make your own with the proper names
